Changing The Logo
Subject: Changing The Logo
How can I change the logo on phpBB XS to my own? I haven't been able to find any reference to this.
Subject: Re: Changing The Logo
For Icy Phoenix, you can modify your template's cfg .... I'm assuming that would be the same for XS
Topic does not apply to FAP - Moved to Icy Phoenix Support ยป General Support
That doesn't work. There is no config file for that template. I can't even find the image for the displayed logo so that I could just substitute my own logo image in its place.
Hi
look in templates/xxx/style_xxx.css
ore change it directly in templates/xxx/overall_body.tpl
Pepi
pepi wrote: [View Post]
Hi
Pepi
OK - I found it. Thanks for the help. As usual it was simple after finding where to look.
One more question for anyone who wants to answer, I'm just getting started with XS. Am I wasting my time, and should I just go on to Icy Phoenix before I get too involved with XS?
sunwest wrote: [View Post]
phpBBXS, at the moment, seems to be abandoned so I think that spend your time with Icy Phoenix is the best choice! :mricy:
Thanks, Buldo, for the response. I'll have to see which one I like best for my use.
Sunwest, you have also to consider that security patches fo phpBBXS probably will not be released :roll:
OK - I hadn't thought of that. I'll probably not spend a lot of time on XS.
I just downloaded and installed Icy Phoenix, but I've got a small problem after installation.
I get these errors when accessing the site, and when attempting to do anything on the site.
Warning: Cannot modify header information - headers already sent by (output started at /home/httpd/vhosts/mysite.com/httpdocs/config.php:22) in /home/httpd/vhosts/mysite.com/httpdocs/includes/page_header.php on line 1490
Warning: Cannot modify header information - headers already sent by (output started at /home/httpd/vhosts/mysite.com/httpdocs/config.php:22) in /home/httpd/vhosts/mysite.com/httpdocs/includes/page_header.php on line 1496
Warning: Cannot modify header information - headers already sent by (output started at /home/httpd/vhosts/mysite.com/httpdocs/config.php:22) in /home/httpd/vhosts/mysite.com/httpdocs/includes/page_header.php on line 1497
Hi
Pepi
I can see overall_header and footer but not overall_body :( where is it gone??
I mean overall_header.tpl sorry
Generation Time: 0.0631s (PHP: 29% SQL: 71%)
