I had updated from XS. I had followed all the steps well.. But now when I enter in the site a lot of errors apear and I cant do nothing..
This is de link http://matias.jtmhostingreseller.com/
sorry for my bud english
A Lot Of Errors, Help Me!!
Subject: Re: A Lot Of Errors, Help Me!!
you are missing this file
/language/lang_spanish/lang_cback_ctracker.php
and you forgot to aply the chmod that are required
I have upload now all lang_spanish, but I did't forget to aply the cdmon...
After cleaning the cache folder there are less errors, but I can't view the forum or the ACP. It says that there are files missing but when I see de FTP that files are there...
The file ...templatesmg_themesportal_page_headerleft.tpl is not 0kb size, I had replesed this file but still have 1kb size
This is wrong? I don't now what to do..
i get this message in http://matias.jtmhostingreseller.com/forum.php
the portal_page_headerleft.tpl is missing in template
upload it
use you XS or IP ???
Pepi
- Template->make_filename(): Error - template file not found: portal_page_headerleft.tpl
upload it
Pepi
Is there... But it seems that is not using the MG template... the template that is using is the ca_aphrodite but i cant enter in the ACP to change it
Xrage wrote: [View Post]
you can upload aphrodite template and change it or change the template via db
Generation Time: 0.1811s (PHP: 11% SQL: 89%)
