Broken External Links On Links.php
Subject: Broken External Links On Links.php
Hey Everyone
I am getting broken link errors from here:
Links MOD v1.2.2 by phpBB2.de and OOHOO and CRLin.
CRLin link is the issue. Is there a way to fix it and turn it off?
Here is its link which is invalid.
http://mail.dhjh.tcc.edu.tw/~gzqbyr/
I tried finding it in links.php and couldn't can someone point me too where I can edit the link.
NOTE: I get more broken links in hacks_list.php here is the bad links:
http://phpbb.rasadam.com
http://mods.db9.dk
http://www.petesplace-online.co.uk
I will probably just filter out this file on the robots.txt to stop this issue.
Just want you to be aware if people run SEO software and things like that you will run into these small issues.
-D1-
Subject: Re: Broken External Links On Links.php
Unfortunately these kind of things may happen...
You can edit the HL files in docs HL folder.
Generation Time: 0.0859s (PHP: 19% SQL: 81%)
