Orange Theme
Subject: Orange Theme
I'm searching a theme with the color orange...it exist for IP(Icy Phoenix)?
Is a bit difficult for me try to re-convert my actual theme (personalized by myself many times ago...) from XS to IP...
Help! :cry:
Subject: Re: Orange Theme
Crucio wrote: [View Post]
Help! :cry:
Which kind of theme/color? Do you have a link?
I may try to help you to port it to Icy Phoenix. :wink:
Help! :cry:
I've a ca-aphrodite modified by myself in background and other color in the CSS file
But now i don't have so much time to try to make the same thing with the theme of Icy Phoenix... :cry:
my site is: ***.manager4life.com
PS: if you want we can talk of this thing via MSN or PM...in italian, sure! :P (i'm in suffering to write in english...eheheh)
Wow, it seems you did a great customization job on your site. :wink:
It should not be a big problem importing those images into the new Icy Phoenix template system.
You should try making some tests with Ice template, just create a new folder for the images and play with mg_themes.cfg for setting up the table headers and footers. :wink:
Off Topic
:shock: Nice style!!! :shock:
ThE KuKa wrote: [View Post]
Off Topic
yes i agree with you ThE KuKa 8)
thanks for the compliments! ;)
But now i need an help for the reconvertion of IP theme, with similar colours of the actual theme ( ***.manager4life.com )...
But now i need an help for the reconvertion of IP theme, with similar colours of the actual theme ( www.manager4life.com )...
Attach here your images in zip format.
I'll try to adapt them to Icy Phoenix.
It isn't a problem of images...is basically a problem to reconvert the css' file!
As I said if you send me the images I will create a theme for Icy Phoenix with those images if you want to distribute them. I'll take care of both images and CSS... :wink:
Subject: re
http://www.manager4life.com/
Forbidden
You don't have permission to access / on this server.
the web dont works
Generation Time: 0.0894s (PHP: 29% SQL: 71%)
