Some Problems In IP
Subject: Some Problems In IP
Have a few little problems I concern IP, I introduce you one at the time.
#1 Even if set the configuration of the FAP correctly up, all the included users the admin are not able to create its Personal Gallery, in fact he the message "not authorized" appears. Why? [Fixed]
#2 When I have set some settings up in ACP > Configuration > Site and so I do click up sends, I this mistake appears:
CBACK CrackerTracker don't execute the operations correctly on the database.
DEBUG MODE
SQL Error : 1064 Syntax error in the SQL query near to 'javascript" type="text/javascript" src="http://adv.helloweb.eu/run/468x60_as/669' linea 1
INSERT INTO ip_ctracker_backup (`config_name`, `config_value`) VALUES ("header_banner_text", "<script language="javascript" type="text/javascript" src="http://adv.helloweb.eu/run/468x60_as/6699CC/003366/FFFFFF/AECCEB/AECCEB"></script>")
Line : 637
File : class_ct_adminfunctions.php
#3 All the users and Mod, excluded the admin, are able to show in the profile of a user the datum "online total duration". Why the admin not? [Fixed]
#4 In the Chat Ajax does not work the BBCode. Why? [Fixed]
#5 in enclosed ACP > Attachments > Control Panel, the page is shown correctly but in high godfather this mistake:
Warning: is_dir() [function.is-dir]: open_basedir restriction in effect. File(../files/..) is not within the allowed path(s): (/usr/share/php:/usr/share/pear:/tmp/:/users/f/p/f/fpf/public_html/) in /users/f/p/f/fpf/public_html/includes/attach_mod/includes/functions_admin.php on line 314
Warning: is_link() [function.is-link]: open_basedir restriction in effect. File(../files/..) is not within the allowed path(s): (/usr/share/php:/usr/share/pear:/tmp/:/users/f/p/f/fpf/public_html/) in /users/f/p/f/fpf/public_html/includes/attach_mod/includes/functions_admin.php on line 314
Ho alcuni problemini riguardo IP, ve ne presento uno alla volta.
#1 Anche se settata correttamente la configurazione del FAP, tutti gli utenti inclusi gli admin non riescono a creare la propria Galleria Personale, infatti gli compare il messaggio "Non Autorizzato". Perchè? [Fixed]
#2 Quando ho settato delle impostazioni in ACP > Configurazione > Sito e quindi faccio click su Invia, mi compare questo errore:
CBACK CrackerTracker non può eseguire correttamente le operazioni sul database.
DEBUG MODE
SQL Error : 1064 Errore di sintassi nella query SQL vicino a 'javascript" type="text/javascript" src="http://adv.helloweb.eu/run/468x60_as/669' linea 1
Line : 637
#3 Tutti gli utenti e Mod, esclusi gli admin, riescono a visualizzare nel profilo di un utente il dato "Durata Totale OnLine". Perchè gli admin no? [Fixed]
#4 Nella Chat Ajax non funziona il BBCode. Come mai? [Fixed]
#5 In ACP > Allegati > Pannello Di Controllo, si visualizza correttamente la pagina ma in alto compare questo errore:
Thanks ^^
Grazie di sopportarmi e supportami :mryellow:
Subject: Re: Some Problems In IP
Fexys wrote: [View Post]
DEBUG MODE
Line : 637
#5 in enclosed ACP > > Control Panel, the page is shown correctly but in high godfather this mistake:
Could you get the bold-underlined errors in english please?
I have edit my first post ^^
Try the new release 1.0.14.14, most of your problems should be fixed.
Let me know if something isn't solved.
I've checked, but I still don't have error number 5.
I need to check the error number 2... it may be related to wrong quotes parsing by CT backup.
In the meantime disable CT backup.
Just checked again number 2 on my site and it is working fine.
Generation Time: 0.0779s (PHP: 23% SQL: 77%)
