SOLVED Similar Topics, Problem!
Subject: Similar Topics, Problem!
i hvae a problem with this MOD ... when active this MOD gives me this error:
Could not get main information for similar topics
DEBUG MODE
SQL Error : 1191 Can't find FULLTEXT index matching the column list
SELECT t.*, u.user_id, u.username, u2.username as user2, u2.user_id as id2, f.forum_id, f.forum_name, p.post_time, p.post_username, MATCH(t.topic_title) AGAINST('Test.. N5') as relevance FROM phpbb_topics t, phpbb_users u, phpbb_forums f, phpbb_posts p, phpbb_users u2 WHERE t.topic_id <> 676 AND t.forum_id IN (32, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29) AND MATCH(t.topic_title) AGAINST('Test.. N5') AND t.forum_id = f.forum_id AND p.poster_id = u2.user_id AND p.post_id = t.topic_last_post_id AND t.topic_poster = u.user_id AND t.topic_status <> 2 GROUP BY t.topic_id ORDER BY p.post_time DESC, p.post_time DESC LIMIT 0,5
Line : 865
File : viewtopic.php
help em, Please
Subject: Re: Similar Topics, Problem!
You didn't upgrade properly.
Rerun update_to_ip.php...
Or try just this to see if it solves your problem.
  1. ALTER TABLE `phpbb_topics` ADD FULLTEXT (topic_title);
ok MG thanks...
lom hill, solved?
Greets
yes is solved... :mryellow: :mryellow: :mryellow:
lom hill wrote: [View Post]
Next time tell us if you solved the problem, ok?
andrea75 wrote: [View Post]
ok, sorry...
Subject: Re: SOLVED - Similar Topics, Problem!
Edit title to Solved :wink:
Thanks!
Generation Time: 0.1191s (PHP: 16% SQL: 84%)
