Lang Missing After Having Modified A Block
Subject: Lang Missing After Having Modified A Block
That's the confirmation. The message is missing:
snapper1180009165984
Subject: Re: Lang Missing After Having Modified A Block
We should need some extra informations to understand what the problem is.
Which files did you modify?
What are you missing?
When did you get that message?
Oh, sorry MG.
I got that message missing every time I update or modify a block in cms configuration. If I create a new block I got "New block added" if I modify a block I got nothing, as shown in the screenshot.
I think that's all you need to see after editing/adding a new block.
If I am not wrong you get that after cliking submit, which finalises the action.
What do you thing is missing?
jz wrote: [View Post]
According to lang_cms.php, when I add a block I have:
$lang['Block_added'] = 'Block added';
So, when I modify it, I thought I would read
$lang['Block_updated'] = 'Block updated';
I see what you mean :)
I think a lang_var is set wrong in one of the .tpl files
I think I fixed it:
in cms.php
fix_weight_blocks($l_id);
$db->clear_cache('cms_');
$message .= '<br /><br />' . sprintf($lang['Click_return_blocksadmin'], '<a href="' . append_sid('cms.' . $phpEx . '?mode=blocks&amp;l_id=' . $redirect_l_id) . '">', '</a>') . '<br />';
message_die(GENERAL_MESSAGE, $message);
elseif( $action == 'delete' )
Replace with:
$message = $lang['Block_updated'] . '<br /><br />' . sprintf($lang['Click_return_blocksadmin'], '<a href="' . append_sid('cms.' . $phpEx . '?mode=blocks&amp;l_id=' . $redirect_l_id) . '">', '</a>') . '<br />';
I applied this on my site and it seems to work, can someone better than me in PHP please check this code?
I think you've done a good job mate..
snap1_1180186441_480862
Vortex wrote: [View Post]
I think I fixed it:
in cms.php
Replace with:
Sorry for bumping, but I upgraded my site just this morning with the latest IP release and I saw that this has not been corrected yet, so I thought it was a good idea ^^
I'll check and eventually add this.
Generation Time: 0.2068s (PHP: 10% SQL: 90%)
