How To Avoid The Webmaster Amount Post?
Subject: How To Avoid The Webmaster Amount Post?
Is possible that the Webmaster have a special number of post, for example: OO or ==.
The users say me, that i ever am the Top Poster, and i want to be not the Top User Poster.
I only want that the Webmaster has a fixed number or characters. And that the messages are not accumulated, ever the same amount.
Thanks for your help dear friends.
Subject: Re: How To Avoid The Webmaster Amount Post?
It is possible, but you have to modify all the pages where number of posts appear... or you have to add an extra SQL to each page.
Too much work :cry:
If exist a SQL will be graceful.
CU Friends.
You can add at end of common.php something like this:
$sql = "UPDATE " . USERS_TABLE . "
SET user_posts = 0
WHERE user_id = 2";
$db->sql_query($sql)
Please remember that you have to change the ID to yours... and pay attention that this adds one extra SQL for each phpBB page... :roll:
I wouldn't use this, but you asked for. :mricy:
Generation Time: 0.2243s (PHP: 12% SQL: 88%)
