How To Hide Post With Minimum Post Count Of The Member
Subject: How To Hide Post With Minimum Post Count Of The Member
Hi my friends,
I want to ask, How to HIDE Post with Minimum Post COunt of member....
If the member had post more than XX posts, he/she can see the hiding post.
example :
  2. [HIDE="20"] hi how are you? [/HIDE]
  3.
  4.
it mean, member (registered) who want to see the hide post must had minimum 20 post in the forum....
i will appreciete to helping me, n maybe this might be useful for the other thx u
Subject: Re: How To Hide Post With Minimum Post Count Of The Member
I don't have the time to code this... maybe someone else is interested and will help you.
Sorry. :mricy:
On bbcode.php, try this
replace
if($userdata['session_logged_in'])
$sql = "SELECT *
FROM " . THANKS_TABLE . "
WHERE topic_id = $topic_id
AND user_id = " . $userdata['user_id'];
$resultat = $db->sql_query($sql);
$show = $db->sql_numrows($resultat) ? true : false;
if ( ($userdata['user_level'] == ADMIN) || ($userdata['user_level'] == MOD))
$show = true;
with
if ($userdata['user_posts']) > 20
$show = true;
Set 20 to the amount of post you want.
Wow, Thx zulker.... it's works
:mricy:
Good shoot Zuker. :P
Generation Time: 0.2101s (PHP: 16% SQL: 84%)
