Different Language Post
Subject: Different Language Post
Thank you so much for Icy Phoenix. I just installed and It's wonderful. Anyway, I am trying to run a vietnamese forum and would like all my users able to post in vietnamese. How do i do that? I appreciate for any comment or advice :mrorange: .
Subject: Re: Different Language Post
look here
http://area69.digi-sky.net/viewtopic.php?f=2&p=132#p132
your charset 'windows-1258'
in lang_main_settings.php change
$lang['ENCODING'] = 'windows-1258';
First, thank you for your respond. 2nd, sorry for being slow. I have change lang_main_settings, just like you said. but nothing different.
If you refer to a translation, search it.
If you refer to the keyboard symbols, just do what difus said.
If you don´t find any translation to the language you want, you can talk with MG about enter the translators group and work on it.
sorry if my last email was not clear, I did metion that I followed his/her instruction. I changed my lang_main_settings, but did not see any different. Also I did research and I only got this . Thank you,
xmenfile wrote: [View Post]
can you show your site ?
try these encodings TCVN or VISCII or VPS
Here you go. it's brand new. let me know. thank you,
Anyone please???
anyone please :cry: :(
:( anyone :cry:
dont push up this topic with your posts so soon after your last post...
if someone can help you, i think he will provide a solution for your problem...
please be patient.
P.S.: you got a yellow card from me!
1st, sorry about double posts. It was an accident, I got an IP's error message when i hit "Submit", I thought it did not post it.
2nd, sorry for a little pushing, 'cause I have searched for couple days w/o any luck.
3rd, I found an answer which i have re-install my phpbb. Can I still able to upgrade it to Icy Phoenix?
PS: I found it, but need your help in IP template.
Here is the instruction: (I am trying to translate it to english on my best).
phần download, mang xuống máy nhà bản mviet14RTEToolBarFeb06.zip -- (Download zip file)
sau khi unzip (bung) nó ra sẽ có folder mviet14RTEToolBarFeb06, (Unzip it and folder will be mviet14RTEToolBarFeb06)
đổi tên nó thành mViet (mẫu tự V hoa) (Rename it to mViet)
upload mViet vô folder phpBB (trong server) (upload it to phpbb root)
Sửa trang /forum/templates/subSilver/overall_footer.tpl, thêm 1 đoạn giữa 2 tags body và html: (edit subSilver/overall_footer.tpl ADD it between </body> and </html>
OPEN subSilver/overall_footer.tpl
</body
</html>
</body>
<script language="javascript1.2" src="./mViet/RTE/CVietButtonHTML.js"></script>
<script language="javascript1.2" src="./mViet/RTE/CVietMoz.js"></script>
<script>folder="./mViet/RTE/" </script>
<script language=javascript1.2 src=./mViet/RTE/CVietAddOn.js ></script>
<style type=text/css>@import url(./mViet/RTE/mviet.css);</style>
</html>
Mở trang /forum/templates/subSilver/posting_body.tpl , tìm dòng có mang chữ textarea và thêm sau nó đoạn màu đỏ: (Edit subSilver/posting_body.tpl)
OPEN subSilver/posting_body.tpl
<textarea name="message" rows="15" cols="35" wrap="virtual" style="width:450px" tabindex="3" class="post" onselect="storeCaret(this);" onclick="storeCaret(this);" onkeyup="storeCaret(this);">{MESSAGE}</textarea>
ADD AFTER
<!--mViet starts-->
<center><div id=showBD>BoDaumViet</div></center>
<!--mViet finishes-->
Save and Close
Off Topic
I do not understand anything, are we talking about a new language package for Icy Phoenix or what? :?
Sorry, I realize this is a mod that let my users able to post in Vietnamese.
Please move it to Support other Mod
I tried to install it in IP templete, but it didi not work. I modified my files just like the above instructions and saved mViet folder in phpbb root directory, but it does not work. Can any help me, please :( ?
here is the Link
Thank you so much,
here is the Link
Thank you so much,
Topic Moved
Generation Time: 0.1425s (PHP: 15% SQL: 85%)
