Problem With Some Icon On Milky Way Theme
Subject: Problem With Some Icon On Milky Way Theme
Hi , i test phpbb3 and i installed milky way theme for phpbb3, but some icons properties r wrong
i mean this:
iconosdesproporcionados
how can i fix it
Subject: Re: Problem With Some Icon On Milky Way Theme
That is really strange, can you give me some extra details please? Which browser are you using? Did you try to refresh the imageset in ACP?
Can you provide a link please?
The problem its solved. i re-installed it and naow worked fine..but now i had a problem with thumbnail...its go over the signature, sorry for my bad english.. take a look:
firma
http://www.adictoalasminas.info/forito/viewtopic.php?f=14&t=53
same error with all the 3 MG styles, workin good with prosilver or another phpbb3 styles.
That is really strange.
Can you try it with subSilver 2 please?
Can you paste here the source code of that post please?
yes, same problem with subsilver2, but i don“t know what u mean "source code".. where is it ?...anyway i use this mod to thumnails
http://www.phpbb.com/community/viewtopic.php?f=70&t=578757
namnl_s_1196059440_204968
The problem is related to that mod... ask the author to fix it with subSilver 2 and you have that solved for Milky Way as well, as they use the same template base.
Generation Time: 0.2837s (PHP: 7% SQL: 93%)
