No Thumbnail // Hotlink
Subject: No Thumbnail // Hotlink
Hi there !
Found another thing on my forum that I find it a lil strange.
When I try to link an image from imageshack (no spam atempt) an antithumbanail images apears instead of the image that I want to link.
for example:
atencion2wv
Can some1 help me please ?
thx in advane.
Subject: Re: No Thumbnail
It's most likely that imageshack does not allow you to hotlink like that.
Escuse me but ur wrong.
I'm using another php forum on the same hosting anf I have no problem with linking, so there must be a config option or something that i don't see :roll: Besides, as u could see the image above is linked without any problem.
Yes you are right and I am wrong ..... don't know what I was thinking when I made my reply :oops:
I've look thru all the ACP settings (as I'm sure you have as well) and didn't notice anything related.... but I could be wrong :mricy:
You have me curious, but I have no explanation .... hang in there, someone will have the answer.
hehe no wories m8, happens...
I'll try to check all over again, pff that's really a mess, thx anyway for ur interes.
Subject: Re: No Thumbnail // Hotlink
Sry for bumping.
Not even changing the .htaccess file, adding exceptions on hotlink will work :?
RewriteEngine on
RewriteCond %{HTTP_REFERER} !^$
RewriteCond %{HTTP_REFERER} !^http(s)?://(www.)?imageshack.us [NC]
RewriteRule .(jpg|jpeg|png|gif)$ - [NC,F,L]
D'oh I'll give up on that :(
Delete this thread if u want....
Generation Time: 0.17s (PHP: 14% SQL: 86%)
