FAP SUPPORT - FAP Nuke Port
Subject: FAP SUPPORT - FAP Nuke Port
Hello,
I'm trying to port FAP 1.4.1 to Nuke to use it with another port of My Profile Space I'm working on. Anyway...all is working great so far except the pictures show up with a red x. I'm thinking it's a path issue since the photo does upload to the right folder but does not display on any of the FAP pages. The problem is, right clicking on the red X's only give a path to a php folder but not the image so I'm having a hard time figuring out how the script calls on the picture to diplay it and which variables are used.
If you would like to see what I mean you can go to www.topfunzone.com use test/test to login and visit this page http://topfunzone.com/modules.php?name=Forums&file=album
I know support will be limited since I'm making this work for Nuke but any advice will be greatly appreciated.
Thanks!
Subject: Re: FAP Nuke Port
Set your album configuration - thumbnails to Yes for View full pic in a pop-up window ....
this will allow you to discover the path.
Setting Quick Thumbnails to Yes in admin config fixed it so some pictures show up. Maybe it's all settings that I'm having trouble with. I'll keep playing around with it but still if anyone has made this work for Nuke or any other ideas are very welcome. Thanks again!
Artie wrote: [View Post]
When I do that, a new page opens as it should but shows the ASCII code for the page instead of a pic and the address bar reflects the php file still.
This must have changed in recent versions. I remember that you once could do this.... :cry:
ptm wrote: [View Post]
Did you try clearing your thumbnail cache after this setting change...... dunno
Cleared the cache. No difference. This is a very deep script and very nicely done. I've seen it work flawlessly on phpbb sites. Nuke is a weird being...I'm pretty good but not this good LOL. Thanks for the continued help!
Was this project ever completed? I tried to port it myself and failed miserably.
Yo
I have ported this album to Nuke-Evolution
and it works like a charm.
i even made some blocks
you can see it working at my website http://www.evilfredx.de
hope you ppl like the results
Thanks for sharing you results, but can you please provide a direct link to album page?
Did you also create a pack (that can be shared with other users) to be integrated into Nuke-Evolution?
Yo here you go
http://www.evilfredx.de/modules.php?name=Forums&file=album
i still have to integrate some minor things but......
ill do a repack in a few days with all the features activated.
Downloadlink
http://www.evilfredx.de/modules.php...downloads&cat=2
(Registration is required)
and here
http://brouhon.kilu.de
i have it running under php5.3.1 after adapting some parts of the code
the only thing what doesnt work under that php version is watermarking
note this release is Nuke-Evolution RC4 REV761 only
there is 1 for the devlopper version though but i would wait until Nuke-Evolution Final is released
of course i can mod 1 for other versions aswell just put a request in my forums
regards ferdi.
PS: the only thing what is not working at all is the downloadfeature
wich only get me some broken zipfiles or unreadable tarfiles but i can live with that.
Thank you very much for sharing your work.
When the official Nuke Evo is out, please open a new topic with tha latest release and I'll "stickify" that.
Regarding ZIP files, try to update the pclzip library with a newer version.
yo
c ya´s :)
Hi ppl,
ive released the FAP for the official Nuke-evolution 2.10 final.
c ya
Download under www.evilfredx.de
but you have to be quick because as of 17.09.2010
i will stop cause of me being sick and not being able to work on my computer anymore
c ya :)
brouhon wrote: [View Post]
I'm really sorry to read this. :cry:
I wish you best of luck with your sickness... and I hope to read you again soon.
Take care.
Thanks for sharing your code.
Same to me...
I wish you all the best brouhon, take care.
Generation Time: 0.1069s (PHP: 20% SQL: 80%)
