where I can change the snow script variables?
thanks
SOLVED Snow Fx
Subject: Re: Snow Fx
but there you can change the algorythm I want to change vars like size, speed...
what I am trying to say it's that the vars
are not defined in the file snow_fx.js, and I want to know where inside Icy phoenix are this vars defined and I can change them
Thanks for your time
var pictureWidth = 10; //the width of the snowflakes
var pictureHeight = 12; //the height of the snowflakes
var numFlakes = 20; //the number of snowflakes
var downSpeed = 0.01; //the falling speed of snowflakes (portion of screen per 100 ms)
var lrFlakes = 10; //the speed that the snowflakes should swing from side to side
hey... sorry for the late reply...
i just found the file :mrviolet:
please take a look into templates/mg_themes/overall_include.tpl
and let me know
and let me know
Ok, found it.
I don't have that file because of a older version but the vars are inside overall_header.tpl in my version
thanks :mryellow: :mryellow:
Generation Time: 0.4548s (PHP: 6% SQL: 94%)
