How To Change Ltr To Rtl ? And Change Charset
Subject: How To Change Ltr To Rtl ? And Change Charset
i didnt find it in the lang files and in the temple, i know there is in css text align : left
but i mean how can i change all the table into rtl if there is no html file?
add any table align right?
i think there muse be some thing easier to do it
*i didnt chek any file so please dont say o realy? i did i find in blablabla
just install today and didnt realy look on it,if you already have an rtl tables i hope you can give me and then i only need change lang files
Subject: Re: How To Change Ltr To Rtl ? And Change Charset
Unfortunately there is no easy LTR TO RTL switch.
You may try to edit lang_main_settings.php or you may try to ask to some RTL translators in the Translations forum.
I have no experience at all in RTL.
Generation Time: 0.462s (PHP: 6% SQL: 94%)
