How Can I Edit Homepage?
Subject: How Can I Edit Homepage?
was wondering how can i remove this:
To disable, delete or edit this block you should access to CMS section (cms.php), select the proper layout (in this case should be 3 Columns) and then edit the block.
Subject: Re: How Can I Edit Homepage?
If you scroll to the bottom of the page (while logged in as admin)
you will see a link to click on in the center bottom of page that says " Edit This Page "
just click on it and you will see all the blocks
or if it is in the CMS then click on the CMS link on the bottom of page and it will take you to the admin. page,
ounce there look at the top right corner you will see links something like this
Admin Index | CMS | Home Page | Forum | Preview Forum | Icy Phoenix Home Page
Generation Time: 0.1842s (PHP: 9% SQL: 91%)
