FAP SUPPORT - Nuffload Upload Error
Subject: Nuffload Upload Error
If your cgi-bin folder is outside of your web_root I would think the path would be
../../cgi-bin/
or
./../cgi-bin/
If it is in your web_root the path would be
../cgi-bin/
Did you create the tmp folder (and set it's permissions) in your cgi-bin ?
FYI: Support for Nuffload is very limited here ... it has been disabled in the Icy Phoenix package.
Subject: FAP SUPPORT - Nuffload Upload Error
Hello i am using
FAP 1.4.1 on my Root Server.
There is PHP-Version: 4.3.9 installed.
My GD Information:
Versiyon: bundled (2.0.28 compatible)
Freetype Fonts Support: Yes
Freetype Link Type: with freetype
T1lib Support: No
Gif Support: Yes
Gif Support: Yes
Jpg/Jpeg Support: Yes
Png Support: Yes
WBMP Support: Yes
XBM Support: Yes
Japonca Font Support: No
I get following Error Mesage if i enable Upload with Nuffload:
Warning: unlink(../cgi-bin/tmp/7b48fc69128a2b73acfce084559698e8_qstring): No such file or directory in /var/www/vhosts/kocubaba.com/httpdocs/Forum/album_nuffload.php on line 207
Warning: fopen(../cgi-bin/tmp/7b48fc69128a2b73acfce084559698e8_qstring): failed to open stream: No such file or directory in /var/www/vhosts/kocubaba.com/httpdocs/Forum/album_nuffload.php on line 208
Warning: fwrite(): supplied argument is not a valid stream resource in /var/www/vhosts/kocubaba.com/httpdocs/Forum/album_nuffload.php on line 209
Warning: fclose(): supplied argument is not a valid stream resource in /var/www/vhosts/kocubaba.com/httpdocs/Forum/album_nuffload.php on line 210
Warning: Cannot modify header information - headers already sent by (output started at /var/www/vhosts/kocubaba.com/httpdocs/Forum/album_nuffload.php:207) in /var/www/vhosts/kocubaba.com/httpdocs/Forum/includes/page_header.php on line 922
Warning: Cannot modify header information - headers already sent by (output started at /var/www/vhosts/kocubaba.com/httpdocs/Forum/album_nuffload.php:207) in /var/www/vhosts/kocubaba.com/httpdocs/Forum/includes/page_header.php on line 924
Warning: Cannot modify header information - headers already sent by (output started at /var/www/vhosts/kocubaba.com/httpdocs/Forum/album_nuffload.php:207) in /var/www/vhosts/kocubaba.com/httpdocs/Forum/includes/page_header.php on line 925
If i disable the perl Upload, i get:
Warning: move_uploaded_file(../cgi-bin/tmp/102b4ca32b1f6da3fa93a177fb27b805_actualdata0): failed to open stream: No such file or directory in /var/www/vhosts/kocubaba.com/httpdocs/Forum/album_nuffload.php on line 107
Warning: move_uploaded_file(): Unable to move '/tmp/phpHInwlu' to '../cgi-bin/tmp/102b4ca32b1f6da3fa93a177fb27b805_actualdata0' in /var/www/vhosts/kocubaba.com/httpdocs/Forum/album_nuffload.php on line 107
Warning: move_uploaded_file(../cgi-bin/tmp/102b4ca32b1f6da3fa93a177fb27b805_actualdata1): failed to open stream: No such file or directory in /var/www/vhosts/kocubaba.com/httpdocs/Forum/album_nuffload.php on line 107
Warning: move_uploaded_file(): Unable to move '/tmp/phpjj64Sr' to '../cgi-bin/tmp/102b4ca32b1f6da3fa93a177fb27b805_actualdata1' in /var/www/vhosts/kocubaba.com/httpdocs/Forum/album_nuffload.php on line 107
Warning: fopen(../cgi-bin/tmp/102b4ca32b1f6da3fa93a177fb27b805_qstring): failed to open stream: No such file or directory in /var/www/vhosts/kocubaba.com/httpdocs/Forum/album_nuffload.php on line 110
Warning: fwrite(): supplied argument is not a valid stream resource in /var/www/vhosts/kocubaba.com/httpdocs/Forum/album_nuffload.php on line 111
Warning: fclose(): supplied argument is not a valid stream resource in /var/www/vhosts/kocubaba.com/httpdocs/Forum/album_nuffload.php on line 112
Warning: unlink(../cgi-bin/tmp/102b4ca32b1f6da3fa93a177fb27b805_qstring): No such file or directory in /var/www/vhosts/kocubaba.com/httpdocs/Forum/album_nuffload.php on line 207
Warning: fopen(../cgi-bin/tmp/102b4ca32b1f6da3fa93a177fb27b805_qstring): failed to open stream: No such file or directory in /var/www/vhosts/kocubaba.com/httpdocs/Forum/album_nuffload.php on line 208
Warning: Cannot modify header information - headers already sent by (output started at /var/www/vhosts/kocubaba.com/httpdocs/Forum/album_nuffload.php:107) in /var/www/vhosts/kocubaba.com/httpdocs/Forum/includes/page_header.php on line 922
Warning: Cannot modify header information - headers already sent by (output started at /var/www/vhosts/kocubaba.com/httpdocs/Forum/album_nuffload.php:107) in /var/www/vhosts/kocubaba.com/httpdocs/Forum/includes/page_header.php on line 924
Warning: Cannot modify header information - headers already sent by (output started at /var/www/vhosts/kocubaba.com/httpdocs/Forum/album_nuffload.php:107) in /var/www/vhosts/kocubaba.com/httpdocs/Forum/includes/page_header.php on line 925
The cgi-bin is root folder, like this:
/cgi-bin
the phpBB is in:
/httpdocs/Forum/
i test it with the paths:
./cgi-bin/
../cgi-bin/
../../cgi-bin/
in the Admin CP. What is the correct Path ?
The Folder permisssions are set correctly !
The cgi Works fine: h**p://***.kocubaba.com/cgi-bin/cgitest.cgi
What is the Problem on my System,
Generation Time: 1.7842s (PHP: 1% SQL: 99%)
SQL queries: 24 - Debug Off - GZIP Enabled
