FAP CUSTOMIZATION - Allow BBcode In Description
Subject: FAP CUSTOMIZATION - Allow BBcode In Description
Hi, i have a problem with the album_page.php(album_showpage.php).
When i add:
if ( $thispic['pic_bbcode_uid'] != '' )
$thispic['pic_desc'] = ( $board_config['allow_bbcode'] ) ?
bbencode_second_pass($thispic['pic_desc'], $thispic['pic_bbcode_uid']) :
preg_replace('/:[0-9a-z:]+]/si', ']', $thispic['pic_desc']);
i get this error:
Fatal error: Call to undefined function bbencode_second_pass() in /home/virtual/mysite.com/public_html/album_page.php on line 162
I dont have CLoWN's Supercharged Album Pack installed. It was working before so it must be something else. Can anybody help find where the bbencode_second_pass is defined?
Here is the mod:
## MOD Title: Allow BBcode in Photo Album MOD description
## MOD Author: cheesypeanut < simonpitfield@frogspawn.org > (Simon
Pitfield) http://www.frogspawn.org
## MOD Description: Allows BBcode in the description field
## MOD Version: 1.0.0
## Installation Level: Easy
## Installation Time: 10 Minutes
## Files To Edit: 6
## album_mod/clown_album_functions.php
## album_cat.php
## album_edit.php
## album_showpage.php
## album_upload.php
## templates/subSilver/album_showpage_body.tpl
## Included Files: n/a
## For Security Purposes, Please Check: http://www.phpbb.com/mods/ for
the
## latest version of this MOD. Downloading this MOD from other sites
could cause malicious code
## to enter into your phpBB Forum. As such, phpBB will not offer
support for MOD's not offered
## in our MOD-Database, located at: http://www.phpbb.com/mods/
## Author Notes:
## REQUIREMENTS:
## This MOD requires Smartor's Photo Album MOD and CLoWN's Supercharged
Album Pack 1
## to both be installed. This MOD also requires an alteration of the
database structure;
## the addition of the field `pic_bbcode_uid` in the `album` table.
## MOD History:
## 2005-02-22 - Version 1.0.0
## - Initial release
## Before Adding This MOD To Your Forum, You Should Back Up All Files
Related To This MOD
#-----[ SQL ]------------------------------------------------
ALTER TABLE `phpbb_album` ADD `pic_bbcode_uid` VARCHAR( 10 ) NOT NULL
AFTER `pic_desc` ;
#-----[ OPEN ]------------------------------------------------
#-----[ FIND ]------------------------------------------------
if ( !defined('IN_PHPBB') )
die("Hacking attempt");
#-----[ AFTER, ADD ]------------------------------------------
$html_entities_match = array('#&(?!(#[0-9]+;))#', '#<#', '#>#');
$html_entities_replace = array('&amp;', '&lt;', '&gt;');
$unhtml_specialchars_match = array('#&gt;#', '#&lt;#', '#&quot;#',
'#&amp;#');
$unhtml_specialchars_replace = array('>', '<', '"', '&');
// This function will prepare a posted message for
// entry into the database.
function prepare_message($message, $html_on, $bbcode_on, $smile_on,
$bbcode_uid = 0)
global $board_config, $html_entities_match, $html_entities_replace;
// Clean up the message
$message = trim($message);
if ($html_on)
$allowed_html_tags = split(',', $board_config['allow_html_tags']);
$end_html = 0;
$start_html = 1;
$tmp_message = '';
$message = ' ' . $message . ' ';
while ($start_html = strpos($message, '<', $start_html))
$tmp_message .= preg_replace($html_entities_match,
$html_entities_replace, substr($message, $end_html + 1, ($start_html - $end_html - 1)));
if ($end_html = strpos($message, '>', $start_html))
$length = $end_html - $start_html + 1;
$hold_string = substr($message, $start_html, $length);
if (($unclosed_open = strrpos(' ' . $hold_string, '<')) != 1)
$html_entities_replace, substr($hold_string, 0, $unclosed_open - 1));
$hold_string = substr($hold_string, $unclosed_open - 1);
$tagallowed = false;
for ($i = 0; $i < sizeof($allowed_html_tags); $i++)
$match_tag = trim($allowed_html_tags[$i]);
if (preg_match('#^</?' . $match_tag . '[> ]#i', $hold_string))
$tagallowed = (preg_match('#^</?' . $match_tag . ' .*?(style[t
]*?=|on[w]+[t ]*?=)#i', $hold_string)) ? false : true;
$tmp_message .= ($length && !$tagallowed) ?
preg_replace($html_entities_match, $html_entities_replace, $hold_string) : $hold_string;
$start_html += $length;
else
$html_entities_replace, substr($message, $start_html, strlen($message)));
$start_html = strlen($message);
$end_html = $start_html;
if (!$end_html || ($end_html != strlen($message) && $tmp_message !=
$html_entities_replace, substr($message, $end_html + 1));
$message = ($tmp_message != '') ? trim($tmp_message) :
trim($message);
else
$message = preg_replace($html_entities_match, $html_entities_replace,
$message);
if($bbcode_on && $bbcode_uid != '')
$message = bbencode_first_pass($message, $bbcode_uid);
return $message;
album_cat.php
$template->assign_block_vars('picrow.piccol', array(
'U_PIC' => ($album_config['fullpic_popup']) ?
append_sid("album_pic.$phpEx?pic_id=". $picrow[$j]['pic_id']) :
append_sid("album_showpage.$phpEx?pic_id=". $picrow[$j]['pic_id']),
'THUMBNAIL' => append_sid("album_thumbnail.$phpEx?pic_id=".
'DESC' => $picrow[$j]['pic_desc'],
'APPROVAL' => $approval_link,
#-----[ BEFORE, ADD ]------------------------------------------
$picrow[$j]['pic_desc'] =
preg_replace('/[img:[a-z0-9]{10,}].*?[/img:[a-z0-9]{10,}]/', '', $picrow[$j]['pic_desc']);
$picrow[$j]['pic_desc'] = preg_replace('/[/?url(=.*?)?]/', '',
preg_replace('/[/?[a-z*=+-]+(:?[0-9a-z]+)?:[a-z0-9]{10,}(:[a-z0-9]+)?=?.*?]/', '',
album_edit.php
include($phpbb_root_path . 'common.'.$phpEx);
include($phpbb_root_path . 'includes/bbcode.'.$phpEx);
$template->set_filenames(array(
'body' => 'album_edit_body.tpl')
$thispic['pic_desc'] = preg_replace('/:(([a-z0-9]:)?)' .
$thispic['pic_bbcode_uid'] . '/s', '', $thispic['pic_desc']);
$pic_title = str_replace("'", "''",
htmlspecialchars(trim($HTTP_POST_VARS['pic_title'])));
$html_on = ( $userdata['user_allowhtml'] &&
$board_config['allow_html'] ) ? 1 : 0 ;
$bbcode_on = ( $userdata['user_allowbbcode'] &&
$board_config['allow_bbcode'] ) ? 1 : 0 ;
$smilies_on = ( $userdata['user_allowsmile'] &&
$board_config['allow_smilies'] ) ? 1 : 0 ;
$pic_desc = str_replace("'", "''",
htmlspecialchars(substr(trim($HTTP_POST_VARS['pic_desc']), 0, $album_config['desc_length'])));
$bbcode_uid = ( $bbcode_on ) ? make_bbcode_uid() : '';
$pic_desc = prepare_message($pic_desc, $html_on, $bbcode_on,
$smilies_on, $bbcode_uid);
SET pic_title = '$pic_title', pic_desc= '$pic_desc'
#-----[ INLINE, FIND ]------------------------------------------
#-----[ AFTER, ADD ]------------------------------------------------
, pic_bbcode_uid = '$bbcode_uid'
album_showpage.php
if( empty($thispic) )
message_die(GENERAL_ERROR, $lang['Pic_not_exist'] . ' -> ' . $pic_id);
album_upload.php
$sql = "INSERT INTO ". ALBUM_TABLE ." (pic_filename, pic_thumbnail,
pic_title, pic_desc, pic_user_id, pic_user_ip, pic_username, pic_time,
pic_cat_id, pic_approval)
, pic_desc
, pic_bbcode_uid
VALUES ('$pic_filename', '$pic_thumbnail', '$pic_title',
'$pic_desc', '$pic_user_id', '$pic_user_ip', '$pic_username', '$pic_time',
'$cat_id', '$pic_approval')";
, '$pic_desc'
, '$bbcode_uid'
<td valign="top"><b><span class="genmed">{PIC_DESC}</span></b></td>
#-----[ REPLACE WITH ]-----------------------------------------
<td valign="top"><span class="genmed">{PIC_DESC}</span></td>
#-----[ SAVE/CLOSE ALL FILES ]--------------------------------
# EoM
Subject: Re: Allow BBcode In Description
thomastoget wrote: [View Post]
## REQUIREMENTS:
Album Pack 1
database structure;
It was working before what ? .... what changed?
This Mod, as written, is not compatible with FAP
I dont have a "clean" FAP but smartors album v2 plus some bits from FAP, Clowns sp-1 and Minc over at Smartor made some cool stuff for me. I love my modded album and will try a bit more before i start a new clean install. I want the bbcodes back... 0060 As said it did work. I dont know when it stopped.. One of my members told me last week. Can be some server-upgrade-bug..
I have backup of all the files changed in every step but it seems like it wont work with the old files either now. I need to figgure out this error.. If somebody has any tip to guide me in the right direction i appreciate it a lot! Thank you.
FAP and Smartors album are more or less the same mod you know.. I will post the solution here when i figgure it out..
Generation Time: 0.2058s (PHP: 9% SQL: 91%)
