PhpbbXS2 Styles
Subject: PhpbbXS2 Styles
Hello, I was looking around for some phpbbxs2 themes
but unfortunatly couldnt find any, i spent some time looking in the Old Styles section but no luck
also did an hour-long google search, but nothing came up.
I was wondering, if there is a database or a few downloads for any phpbbxs2 themes.
Thanks For Your help
-Zealo
Inactive User
Subject: Re: PhpbbXS2 Styles
Look at the top banner - It says Icy Phoenix.
You're at the wrong site and wrong forum, looking for what you want. :shock:
So how could anyone treat this as a serious question.
Topic moved to chat??
maybe this can help
http://www.mergenine.com/forums.html
http://www.phpbb2plus.de/
:wink:
AFAIK phpBB XS is not developed anymore... I doubt you will be able to find any template for it.
Hi Zealo, why you want to upgrate from phpBBXS to IcyPhoenix?
Lopalong wrote: [View Post]
Well, as far as i know, phpbbxs2 turned into Icy Phoenix so thats why i posted here, sorry if i caused any trouble.
if there are no templates for xs2, is there an upgrade to turn xs2 into icy phoenix without losing any posts or information?
In install folder now you have some extra files you may use to convert your board, delete old files, fix db tables...
  • install.php: this is for brand new installations.
  • update_to_ip.php: this is for upgrading from phpBB or any XS or Icy Phoenix versions.
  • clean_tables_ip.php: if you want to clean up your tables, resetting them to the default Icy Phoenix ones, you can use this files. This file is meant for standard Icy Phoenix, not for modded versions. This file may be used even when upgrading from other platform: phpBB Plus, IntegraMOD, FullyModded... etc. Please note that this action cannot be undone, make sure you have a full db backup before proceding.
  • clean_old_files_ip.php: this files will delete all unused files from previous installations of Icy Phoenix. Please note that this action cannot be undone, make sure you have a full backup of all files before proceding. (This file may not run correctly on some servers configurations)
Generation Time: 0.311s (PHP: 6% SQL: 94%)
