I have "allow html" set to "yes" in the ACP on one of my forums, but it is not functioning correctly in the posts. The odd thing is, it does function correctly in the preview of the post. I use Icy Phoenix on numerous forums and it works on at least one other I checked tonight at http://mexicansgohome.com/viewtopic.php?f=9&p=740#p740 .
I also have the "a" tag listed in the ACP under site configuration. I am using V 1.2.0.27 on both sites. I upgraded the one where it is not working with the latest cumulative patches, but this did not fix the problem.
The html is simply included in the post. http://concealedpistol.org/viewtopic.php?t=34&p=45#p45
BTW, "Disable html" is not checked when posting the message. What gives? :?
Html Does Not Work In Posts
Generation Time: 5.0532s (PHP: 1% SQL: 99%)
