Quick Question About Ranks
Subject: Quick Question About Ranks
In my old forum (Invision) there was the possibility to let users choose a rank by themself. Withouth image, in personal cp they could set a "personal title" to appear just under the avatar.
In phpBB I didn't find this possibility, does anyone know a mod capable to do that?
Subject: Re: Quick Question About Ranks
It is possible using Shop Mod... or more simply by creating a customized field in ACP and let the user fill it. :wink:
I tried adding a customized field, the only ugly thing is that it puts the title of the field... I'll try this shop mod and let you know ;)
Vortex wrote: [View Post]
He he he... but you may even create a new position for Custom Profile Fields and not inserting the Field description.
If you have a little knowledge of PHP you should be able to do this in few minutes. :wink:
Just copy what has been done for other positions. :wink:
I don't have any knowledge of php :D But if you give me a shot of what the code should be I can try
Dai uno sguardo a questo file: functions_profile_fields.php.
Qui vengono generati i campi personalizzati... basta rimuovere l'etichetta nel campo autore e spostarlo nel template dove vuoi tu! :wink:
Uau addirittura in italiano :oops:
Scusami, ci ho provato, ma non sono riuscito a capire come fare... quale parte di codice devo eliminare? In quale file trovo il template che genera il profilo accanto al post? :(
Does anybody know which template generates user's informations next to the post?
Ok, solved as follows:
From includes/functions_profile_fields.php I found the function that generates profile fields:
  1. if($location == AUTHOR)
  2. {
  3. //$cp_udata_cache[$id]['author'][] = ($profile_names[$name]) ? $name . ': ' . $profile_names[$name] : '';
  4. $cp_udata_cache[$id]['author'][] = ($profile_names[$name]) ? $field_name . ': ' . $profile_names[$name] : '';
And I cut the variable $field_name which shows the profile name:
  2. {
  4. $cp_udata_cache[$id]['author'][] = ($profile_names[$name]) ? $profile_names[$name] : '';
Then in templates/ca_aphrodite/viewtopic_body.tpl I moved the code that generates the field, forcing it to appear just under the avatar. I took
  1. <!-- BEGIN author_profile -->
  2. {postrow.author_profile.AUTHOR_VAL}<br />
  3. <!-- END author_profile -->
and put it just after
  1. <!-- BEGIN switch_showavatars -->
  2. <span class="post-images"><a href="javascript:quotename('[b]{postrow.POSTER_NAME_QQ}[/b],')">{postrow.POSTER_AVATAR}</a></span>
  3. <!-- END switch_showavatars -->
  4. <div class="post-details">
Then, in order to make it similar to Invision, I centered it and separated it from other informations just using html tags <center> e <br />
  2. <center>{postrow.author_profile.AUTHOR_VAL}</center><br /><br />
Wasn't so difficult, was it? ;)
See... you could do it ;)
He he he... I think that someone helped him! :mrb:
:oops:
Generation Time: 0.268s (PHP: 7% SQL: 93%)
