Problem With Black_pearl When I See A New Topic
Subject: Problem With Black_pearl When I See A New Topic
I don't know exactly why when i wan't to see a new topic the margins is not keept. i will attach some photo to see exactly the problem.
Where i put the arrows in the picture is the problem
untitled
The first picture have good margins
untitled1
the second picture have a bad margins.
Someone can help me to corect this problem?
Subject: Re: Problem With Black_pearl When I See A New Topic
Do you have any link for your page? Would help to get an impression of what you mean.
Cause could it maybe be that the image in the header is centered and so displayed in the middle of your page... That would describe the problem you describe with the images i can see.
Here is the Link . But you must register first
And here is the code in overall_header for logo :
<div id="top_logo">
<td height="200" width="940" align="center" valign="middle"><a href="{U_INDEX}">{SITE_LOGO_IMG}</a></td>
</table>
thanks
the top logo is centered as i supposed:
  1. <td height="200" width="940" align="center" valign="middle"><a href="./index.php"><img src="./styles/black_pearl_1/imageset/site_logo.jpg" width="940" height="200" alt="" title="" /></a></td>
Your board has a width of 940px. Before i register there can you have a look to that page and tell me if there are images displayed that are bigger than 940px? That would explain that the board width is extended.
It happen even if is not a picture there. It's general problem when someone post and i want to see what he post than it happen. And after i read what he rote and make a refresh then i see the page normal
Dunno looks good for me
only this page:
http://www.forum.evilzone.ro/viewtopic.php?f=42&t=183
showed the extended board width. But there it is coming from the banners in that forum. Thats what i meant - if you have pictures that are displayed with a width of more than ~700px they will extend the board width.
Therefore i am using Airbox Image Resizer Mod - cause i had those probs as well.
it is because of this
untitled1
And how i can remediate this problem?
It happens only when i see a new post reply
what lang you use ?
for example you can made shorter names of navs (in you lang) or remove some of them (like that "trinite print e-mail unui bla bla ... )
I use romanian language, i will try to change.
thanks
I changed back to english and is ok.
I have another question If i wanna change the margin from 960px to 100% how can i make the top logo to resize to 100%
The logo size is 200x940 px
gogubeb wrote: [View Post]
thanks
if you want use 100% for with or any % there is no chance to made logo to be in % ...it will ever be different on diferent monitor resolutions , but
what you can do is to create a logo which will strech and enlarge by backgrount image
this image (example 2 x 200px ) will be repeted by " repeat-x to eternety ...so one part of your logo shoud be same as this tiny picture ...
in your case this image is called "top_header.png" in your styles\black_pearl\theme\images\
i m not sure if you understand this ...
Generation Time: 0.3159s (PHP: 12% SQL: 88%)
