Milky Way Red Parse Error Code T_ELSE
Subject: Milky Way Red Parse Error Code T_ELSE
Thanks for Viewing.
Okay, i do believe it's the milky way red style seeing as subsilver still works.
When you click on a topic this appears:
Parse error: syntax error, unexpected T_ELSE in /home/*******/public_html/forum/includes/template.php(187) : eval()'d code on line 74
Then if you refresh you get this:
Parse error: syntax error, unexpected T_ELSE in /home/********/public_html/forum/cache/tpl_milky-way-red_viewtopic_body.html.php on line 74
Also this is lines 70-78 in the cache in relation to the error aboce:
71 <td>
72<?php if ($this->_rootref['S_IS_MULTI_CHOICE']) { if ($_poll_option_val['POLL_OPTION_VOTED']) { ?> checked="checked"<?php } ?> />
73<?php } else { ?>
<input type="checkbox" class="radio" name="vote_id[]" value="<?php echo $_poll_option_val['POLL_OPTION_ID']; ?>"<?php if ($_poll_option_val['POLL_OPTION_VOTED']) { ?> checked="checked"<?php } ?> />
74<?php } else { if ($_poll_option_val['POLL_OPTION_VOTED']) { ?> checked="checked"<?php } ?> />
75<?php } ?>
76<input type="radio" class="radio" name="vote_id[]" value="<?php echo $_poll_option_val['POLL_OPTION_ID']; ?>"<?php if ($_poll_option_val['POLL_OPTION_VOTED']) { ?> checked="checked"<?php } ?> />
77<?php } ?>
78</td>
I did do some research and came across this error dealing with some "<!-- Begin -->" tags, though in template.php i can't find any begin tags.
Any help would be appreciated.
[EDIT]: I forgot to mention i have installed the Advanced Point System Mod "Points_0.9.1"
-Corman
Subject: Re: Milky Way Red Parse Error Code T_ELSE
  1. <?php if ($this->_rootref['S_IS_MULTI_CHOICE'])
  2. {
  3. if ($_poll_option_val['POLL_OPTION_VOTED'])
  4. {
  5. echo 'checked="checked"';
  6. } echo ' />';
  7. }
  8. else
  9. {
  10. echo '<input type="checkbox" class="radio" name="vote_id[]" value="'.$_poll_option_val['POLL_OPTION_ID'].'"';
  11. if ($_poll_option_val['POLL_OPTION_VOTED'])
  12. {
  13. echo 'checked="checked"';
  14. } echo '/>';
  15. }
  16. else
  17. {
  18. if ($_poll_option_val['POLL_OPTION_VOTED'])
  19. {
  20. echo 'checked="checked"';
  21. } echo ' />';
  22. }
  23. echo '<input type="radio" class="radio" name="vote_id[]" value="'.$_poll_option_val['POLL_OPTION_ID'].'"';
  24. if ($_poll_option_val['POLL_OPTION_VOTED'])
  25. {
  26. echo ' checked="checked"';
  27. }
  28. echo ' />';
  29. } // I think it's from some other block, but ...
As u can see, the problem is become there is two "} else {". Could we have the .tpl file, line 70-80 ?
did you maybe forghet to tell as that this problem is since you instaled Points_0.9.1 ?
:mrviolet:
in my opinion you miss some <!-- ENDIF --> in viewtopic.html :oops:
but as Informpro sayed we cant know without whole code
[EDIT]Look at last post.
no man not this from cache
post your styles\milky_way_red\template\viewtopic_body.html
or try simple test
upload original viewtopic_body.html of milky_way_red
beckup this your before
Limun wrote: [View Post]
or try simple test
I did replace with original which worked.
Then i took that original added the points line and that works too.
So everything is up and running perfect now. (*even though i compared the files and didn't see a difference*)
Thank you Limun for all your help in this and the other topic i had.
Thanks again
-Corman
I have an similar error
I installed Topic Text in Mouse Over h**p://***.phpbb.com/community/viewtopic.php?f=69&t=1257235
And when i try to enter in a forum ( viewforum) i am getting an error
Parse error: syntax error, unexpected T_ELSE in /hsphere/local/home/cstrike/whatsfunny.ro/forum/cache/tpl_subsilverPlus_viewforum_body.html.php on line 60
I use subsilverPlus style.
The code from the 60 line is this
55 <td class="row2" width="130" align="center"><p class="topicauthor">{topicrow.TOPIC_AUTHOR_FULL}</p></td>
56 <td class="row1" width="50" align="center"><p class="topicdetails">{topicrow.REPLIES}</p></td>
57 <td class="row2" width="50" align="center"><p class="topicdetails">{topicrow.VIEWS}</p></td>
58 <td class="row1" width="140" align="center">
59 <p class="topicdetails" style="white-space: nowrap;">{topicrow.LAST_POST_TIME}</p>
60 <p class="topicdetails">{topicrow.LAST_POST_AUTHOR_FULL}
61 <!-- IF not S_IS_BOT --><a href="{topicrow.U_LAST_POST}" <!-- IF topicrow.LAST_TEXT_HOVER -->title="{topicrow.LAST_TEXT_HOVER}"<!-- ENDIF -->><!-- IF topicrow.LAST_TEXT_HOVER -->{topicrow.LAST_POST_IMG}<!-- ELSE -->{LAST_POST_IMG}<!-- ENDIF --></a><!-- ENDIF -->
62 </p>
63 </td>
64 </tr>
Could someone help me?
Sorry for my bad english.. I am trying to learn it :?
... code in cache folder ? (.php) (compilator move line ..)
Generation Time: 0.0925s (PHP: 20% SQL: 80%)
