I'm a newbie so please bear with me!
I would like to make the width of the PHPBB "table" smaller. But I am having problems finding where the change the dimensions.
I am using the Milky Way Theme. I would like to shave about 200 pixels off of the right hand side of the forum page. Both on the index page and on the internal forum pages. I want to be able to put advertising space there.
Any help would be greatly appreciated. If this is in the wrong place, please forgive me!
Thanks in advance for your help in this matter!!!!!
CSS Help I Guess
Subject: Re: CSS Help I Guess
is it milkiy way for phpbb3 or for icyphoenix ?
BTW as i understand you want 200px of space on right side,right ?
sounds like a change in 3 colums of Icy. just create a new block there you put your advertise and disable or relocate some other blocks
Sorry Limum, I should have gave a more complete question!
I'm using PHPBB3 Milky Way Red theme. And yes, I want to shave off about 200 pixels off of the right hand side to put some advertising there.
Spydie,
I'm not sure what you mean so PLEASE talk to me like I'm 8 years old!! And "ABC" me the steps on how to configure this!!
Limun wrote: [View Post]
spydie wrote: [View Post]
Spydie,
sry but i´m not familiar with PhpBB3, I´ve been talking about IcyPhoenix.
The CMS is totaly different there
now i ask this
what resolution you are using
because i see milkyway like this
and where is that space you want (see pic)
no:1
no:2
no:1
no:2
Limum,
I would LOVE to see that!!
I have a flat screen and am at 1280x1024.
Limum,
ok you can to in this way
if you like it do this
open your styles\milky_way_red\template\overall_header.html
find
before add
thats all
{T_THEME_PATH}/images/nothumbnail.jpg is path to your sponsor pics
hope you like it :wink:
PS..that images "no thumbail" are only for demonstrate you
find
before add
thats all
Generation Time: 0.6287s (PHP: 3% SQL: 97%)
