Blackpearl Background Change
Subject: Blackpearl Background Change
i have look over and over in the internet to seee where and how i can change all the background from this forum i not find anything work plz help me what i wabnt to do its change the black color to a image background repeat-y or x so i can see a image background in my forum if you can help it will be apreciate thanks
Subject: Re: Blackpearl Background Change
hi there,
try looking at the stylesheet.css, somewhere at the top you find "body"
i try to change the body like in 10 way but nothing :(
did you purge the forum cache and clean the browser cache after doing the edits and before checking?
stylesheet changes are not in forum cache - it does not have to be refreshed. He does have to refresh the browser, though.
i have try a lot of thing but i just change my style and got a new problem not have a ACP link in the dirty board 2.0 im getting really sad nothing work great :(
incase you need to go to the admin panel and link is missing:
http://your_forum_url/adm
lazydragoon wrote: [View Post]
The background color for the forum is listed in a lot of places in this style (Black Pearl). Changing the body tag alone will not do what you want, since literally ALL the colors of the style use a different BG color, ranging from #111111, to #121212, to #232323 - depending on where the color is. The basic background color in Black Pearl is #11111, so if you look for that in the stylesheet you will get an idea how many times it has to be changed.
It would be far easier to work with a different style that has the basic colors you want than totally trying to change Black Pearl in my opinion ... unless you are a masochist:)
ooooh silly me ... i was thinking he wanted to know where he could change black into a back ground pic
Nope - you are correct. I missed that:( I was thinking changing the color. My mistake. Definitely something I have no clue about.
Can you please exactly show us where do you want the background being shown?
Or at least a style which has a similar feature?
Generation Time: 0.1929s (PHP: 11% SQL: 89%)
