Settings Tags
Subject: Settings Tags
1st - can we regulate the Tags to show words consisting of more than 4 (or 5) letters;
2nd - can we exclude words from the Tags which is useless for search engines.
Example (00ff00 arrow cyan font LOL mryellow razz red size).... etc
(I am not so sure if I put this in the correct section)
Subject: Re: Settings Tags
Hey friends.
I read your post it is really good thinking.
You need to edit language/lang_*/search_stopwords.txt adding there the words you don't want to appear.
You also need to rebuild search table then...
Thanks Luca for the advice but I think that is not working properly !!
It removes the link from the words I put in language/lang_*/search_stopwords.txt , but it still shows the words in the Tags.
I note u that I try it on localhost environment
You need to rebuild the Search Table after having changed that file.
It will require some time... make sure you have a backup.
Generation Time: 0.1784s (PHP: 11% SQL: 89%)
