SOLVED Share This Topic
Subject: Share This Topic
Share this topic ... where can I find in the ACP to activate it?
Subject: Re: Share This Topic
Do you mean the share social Bookmarks?
If so, ACP >> Configuration >> Icy Phoenix >>Posting And Messages >> Social Bookmarks (select yes)
14_03_2011_20_11_29
I have no option to choose in my ACP!?
Are you running on PhpBB or on IcyPhoenix ??
don´t know why, i got this feeling , you´re on PhpBB
icyphoenix....
http://www.psp-2.org
Off Topic
Nice site Awex but I noticed a small thingi with hovering the marqee message box at the top of your indexpage..
Your border on hover needs a small adjustment because the way it is now when you hover that little box the full page feels a small aftershock :mryellow: (it jumps a bit)
don´t know why, but this marquee box looks like from FB
awex wrote: [View Post]
Are you the main admin or did somebody ells start the site?
Some ACP features are hid unless the main admin, not sure if this feature is within that part?
If your not the main admin, maybe this thread will help
http://www.icyphoenix.com/viewtopic.php?f=2&t=7697
Hi awex...
Das findest du im ACP unter Konfiguration -> Icy Phoenix Einstellungen -> Beiträge und Mitteilungen
Öffentliche Lesezeichen
Zeige Öffentliche Lesezeichen bei den Themen
Verlinke dieses Thema
Zeigt die "Verlinke dieses Thema" Box beim Lesen eines Themas.
yes sure I am the main admin
@ kugelsicha..
thx
Public Bookmarks
View Public bookmarks with the subject <-------- YES. that was not marked
Link to this subject
Shows the "Link this issue" box while reading a topic.
great you solved the error ;)
Maybe try re-uploading adm and templates/common/ACP
Generation Time: 0.1043s (PHP: 18% SQL: 82%)
