FAP SUPPORT - Problem With Viewing Galleries Without Logging In
Subject: FAP SUPPORT - Problem With Viewing Galleries Without Logging In
Hi there
I've installed the Full Album Pack 1.2.1 on my phpBB.
Until I've changed the configuration for personal user galleries from
"Who is allowed to view personal galleries: Everyone or All" to "Registered"
it was no problem to view pictures without logging in ...
When I tried to switch it back to "all", the effect was the same as with "Reg".
The selectbox shows "all" but it does not work. You still have to be logged in,
to view them ...
How to change it back?
Subject: Re: Problem With Viewing Galleries Without Logging In
Please, upgrade to FAP 1.4.0 and then try again...
If you are still having problems, we will help to fix them. :wink:
first of all ... thanks for your answer ... :-)
is there a possibility just to update the FAP or is it like modifying everything again?
I have written an update from FAP 1.2.3... 1.2.1 is quite old... but you may try to upgrade to 1.2.3 first and then to 1.4.0...
You have to download FAP 1.2.3 @ MG.com first.
Good Luck!
Generation Time: 0.1555s (PHP: 11% SQL: 89%)
