SOLVED FAP SUPPORT - OTF folder - access denied
Subject: FAP SUPPORT - OTF folder - access denied
krisbfunk wrote:
having issues accessing images in the OTF gallery, I see the thumbnails, but get a forbidden error when trying to view the direct images.. permissions problem i assume, but all subfolders of album_mod are set to 777.
  1. Forbidden
  2. You don't have permission to access /forum/album_mod/upload/otf/2up/2up.jpg on this server.
  3.
  4. Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request.
this was after an upgrade from 1.2.3.. OTF worked perfectly before the upgrade.
Artie wrote:
Try using the .htaccess files from FAP 1.4.0 final (in the upload and subfolders) .... or remove them altogether.
krisbfunk wrote:
ok, i replaced them with the old .htaccess files from 1.2.3 and it worked. thanks!
Subject: Re: OTF folder - access denied
Great Artie! :up:
Not only... in Icy Phoenix you should need to remove the HTACCESS even in the files folder... :roll:
I need to study how HTACCESS work, because this is an unwanted effect of the latest structure changes I did... :roll:
Generation Time: 0.3023s (PHP: 6% SQL: 94%)
