Hide Mod Customization
Subject: Hide Mod Customization
Hi Icy
I need a help to customize the mod hide.
I had in icy 1.3 it like this:
2el3x5i
A year ago, using this code.
but now it does not work, but when I connected dont see links:
p9nsrou
Subject: Re: Hide Mod Customization
It just looks and sounds like the image is missing:
http://animetal.com.ve/images/bbcb_mg/images/hide.png
AND it looks like you did not fix postcounting yet and spam protection is switched on again, like explained in the other topic.
PS..
I am constantly redirected to adfly when I visit your site!!! :evil:
PS..
I want just redirected links adf example: mediafire and other
sorry.
I have to review the code adf
And the previous post is not count
"Look at the themes and messages in forums Subjects: 16777215
Posts: 16777215" O.o?
______________________________________________________________
Edit: Look i add the hide.png and nothing:
hide
I do see hide.png in the post now
User's post count is still 0, look below user's avatar and see!
"Posts: 16777215" but is 0 still.
the hide when is offline i dont see the links
And when is online i dont see the links, I see no links connected or disconnected
Well you seem to have changed the link back to default path so now the image is missing again but ....clean your browser :wink:
About links being invisible again.... spam protect is on or off?
the problem with hide is this:
when is online:
zxzael5
And offline is:
dyw3hvm
I dont see the links with hide active.
online or offline i dont see the links.
Now the spam:
3a2pcev
This mod hide was esnola hide modification of all-mods
Remember That modified two files bbcode and other but ... I forget which was
Really you should try and search for the mod yourself but here's the mod:
http://www.icyphoenix.com/viewtopic...&highlight=hide
(I'm not saying it's good for IP2! maybe yes .. maybe no)
You should also try to do what is advised:
- Upload the images in the correct location
- Clear your browser!!
- Fix each forum to count posts for user's postcount
- then Re-enable spam protection
- You may also have to "Synchronize user post counters" in Database Maintenance (or just make a new post
I also don't understand why you did not import your old DB? (if you have one)
I see before this post
the trouble is that we have to thank for showing the links.
Did have a database before but was very large and had almost 1 GB with hosting problems i had to hire a vps and then I could not keep. After a year I'm starting again from 0.
Madara wrote: [View Post]
Then maybe you can try this (I don't know if it will work):
Zuker wrote: [View Post]
leonidfg wrote: [View Post]
Hi again... in all this HIDE button stuff I have another question.
There's a way to the hide messages may be visible only to the registered users without the need of posting a message? An example may be the Thanks button that allow to see the hide messages.
But I didn't find a post with this Thanks button MOD.
Anyone here know how to do it.
Bye...!
on bbcode.php & viewtopic.php
replace
if($userdata['session_logged_in'])
$sql = "SELECT p.poster_id, p.topic_id
FROM " . POSTS_TABLE . " p
WHERE p.topic_id = $topic_id
AND p.poster_id = " . $userdata['user_id'];
$resultat = $db->sql_query($sql);
$show = $db->sql_numrows($resultat) ? true : false;
if ( ($userdata['user_level'] == ADMIN) || ($userdata['user_level'] == MOD))
$show = true;
with
if ( ($userdata['session_logged_in'] )
$show = true;
test it :v:
Wow If it works, using the original file bbcode.php besides, that i modify it a bit and ready. :v:
:mryellow: Look: j9bhkdz
Well done Madara, looks very nice! :wink:
BTW I lke the thank image, it's the first time anybody said thanks to me like this :mrorange:
I'll mark this topic SOLVED for you, next time you can do this yourself using "Title Edit" at bottom right of the page, please do.
Generation Time: 0.1256s (PHP: 27% SQL: 73%)
