Guys,
After upgrading to PHP 5.5 and apache 2.2.4.7 i am face with a problem-- if i type the location of my website:-
www.scotbird.co.uk/scotforum/index.php -- i get a blank page ( both firefox and IE )
if i type in
http://www.scotbird.co.uk/scotforum/login_ip.php -- i get the login page ( Firefox only ) which when i login i am taken to
http://www.scotbird.co.uk/scotforum...97522e863c0fe54
which is a blank screen ( pure white no text ), This is on IP2.0 which i have just recently set up and as yet have not transfered my users onto. I can however say that IP1.53 is still running after the update ( i had to change a time zone setting but that was all ) on IP 2 its as if re-directs re not working correctly.
This only started after the upgrade.
I am a newbie when it comes to setting PHP setting, i used scripts to do the updating for me from 5.3 to 5.5.
Appreciate any support.
SOLVED After Login Blank Page On IP2 After Apache And PHP Upgrade
Subject: Re: After Login Blank Page On IP2 After Apache And PHP Upgrade
Can you install a fresh copy of Ver2* (Preferably from GIT - With NO added extras) to a new database and see what happens?
Subject: [ SOLVED ] Re: After Login Blank Page On IP2 After Apache And PHP Upgrade
Thanks Mort, i have just found the fault thanks to the error log, log was saying -
Call-time pass-by-reference has been removed in /var/www/scotforum/includes/album_mod/album_functions.php on line 1035
on line 1031 and 1035 i changed the &$results variable to $results as advised on
http://wordpress.org/support/topic/...been-removed-in
Please mark this as solved, now for my other problem, but too late tonight going to bed, fresh head tomorrow.
Don't know why you had to google for an answer at wordpress?
One only has to search for "Call-time pass-by-reference" here.
But then - You never reported any "error" messages?
http://www.icyphoenix.com/viewtopic.php?p=59420#p59420
http://www.icyphoenix.com/viewtopic.php?p=59436#p59436
It's also been discussed here before as there are actually more locations that need to be edited - Unless one downloads the Icy-ZIP from GIT-Hub.
Mort,
Didnt specifically look at wordpress, i went to google and done a search.
I hadnt looked at the error report log until after i had posted the original message.
Anyway alls good.
Anyway alls good.
Generation Time: 0.2514s (PHP: 22% SQL: 78%)
