i have a litte problem , i think the "Show fill GIF pictures,if Mid Thumb activ." dosent work
when i click on a gif pic the midtumbnail will show anyway.
have a look
--->link
maybe try the animated NIN banner or someting else
EDIT:
uhm ... there a some pics shown up right ... like this Multi Upload - 004
but the animated gif banner wont show up right --> Nin
FAP SUPPORT - Gif Pictures And Midthumbnails
Subject: Re: Gif Pictures And Midthumbnails
I think you may be right.... I see no difference no matter how I set the ACP for this.
What are trying to make happen ?
Do you want the thumb to link to the full image and skip the mid-thumb (for gifs) ?
BTW, I really like what you have done to the image info ..... Cool 8)
Anemia wrote: [View Post]
hey,
yes i want skip the midthumbnails for gif pictures. Some of the Gifs a animated and must have a fullview to show up right.
thanks for the compliment respective the Image Info :)
and thanks for your great support :mryellow:
I find nothing to suggest that this feature is actually coded ... except for the ACP. :?
Perhaps MG has discontinued this for some reason and forgot to remove from the admin panel.
Damn... you two found another bug...
OPEN album_picm.php
Let me know it it will work in this way... :roll:
Artie wrote: [View Post]
OPEN album_picm.php
// Send Thumbnail to browser
if ( ($pic_filetype == '.gif') && ($album_config['show_gif_mid_thumb'] == 1) )
header('Content-type: image/gif');
header('Content-Disposition: filename=' . $pic_title_reg . $pic_filetype);
readfile($pic_fullpath);
exit;
exit;
Generation Time: 0.1373s (PHP: 12% SQL: 88%)
