So I was making custom profile fields and accidentally made a user_rank custom field.
IP went ahead and gave me an error but did it anyway.
I tried removing the custom field, and lost access to forums.
I put the user_rank custom field back and everything is normal again.
I knew enough to remove user_rank from the custom fields admin panel, but is something horribly screwed up?
User Database Mistake
Subject: Re: User Database Mistake
I think you're right... We need to add checks to make sure we're not superseding fields that already exist...
If it helps the community I am all for it 8).
What can I do with my tragedy to help?
First, I want to make sure -- do you have any lingering issues, or is everything resolved?
Then, we'll need to code some safeguard.
Generation Time: 0.3514s (PHP: 5% SQL: 95%)
