Post Changing RSS Feed Charset
If you have problem with the feed on IE
OPEN rss.php
FIND:
  1. 'S_CONTENT_ENCODING' => $lang['ENCODING_ALT'],
REPLACE WITH:
  1. 'S_CONTENT_ENCODING' => $lang['ENCODING'],
058-004 Rss Feed.zip
Filename: 058-004 Rss Feed.zip
Filesize: 7.41 KB
Downloaded: 621 Time(s)
Zubr sole verde cucchiaio
BicetSend private messageVisit poster's website
Post Re: 058-004 - FIXED - RSS Feed
Bicet, the file I've downloaded here contains a MacOS folder
www.LphantES.com
zankywSend private messageVisit poster's website
Every time I try to add a news feed using XS, it says:
Unable to open the XML input: http://www.whateversite.com
Round11Send private messageVisit poster's website
Bicet wrote: [View Post]
OPEN rss.php
This modification was made by MG under my request to have a different encoding table for RSS and I find it very useful. You can use the same encoding table instead deletng "ENCODING_ALT", or not?
Round11 wrote: [View Post]
 This is your site or the one you want include in your RSS feed?
~~~ Andrea ~~~
User #379756 on Linux Counter
buldo wrote: [View Post]
OPEN rss.php
Well, I just put http://www.whateversite.com as an example.  It doesn't matter what site I use their XML feed from, but that's what I get regarless.
The RSS still doesn't works with IE. The error message is:
The XML page cannot be displayed
Cannot view XML input using style sheet. Please correct the error and then click the Refresh button, or try again later.
System does not support the specified encoding. Error processing resource 'http://www.phpBBXS.eu/rss.php'.
Bicet, that is not a bug... I've added that line to allow people to have feed in more than one lang.
You can change the setting in lang_main.php, by changing this line:
  1. $lang['ENCODING_ALT'] = 'utf8';
to
  1. $lang['ENCODING_ALT'] = 'iso-8859-1';
I'll move this to Docs section.
Post Re: Changing RSS Feed Charset
MG, the RSS still doesn't work on IE.... try to open
and you'll see that error
Impossibile visualizzare la pagina XML
Impossibile visualizzare l'input XML tramite il foglio di stile . Correggere l'errore, quindi fare clic su Aggiorna, oppure riprovare in un momento successivo.
La codifica specificata non è supportata nel sistema. Errore durante l'elaborazione della risorsa "http://www.phpBBXS.eu/rs...
<?xml version="1.0" encoding="utf8" ?>
Try installing this patch, and let me know:
http://www.icyphoenix.com/viewtopic.php?t=183
Yes, now rss works fine!
Wow... what a tough job with these RSS... the code is not so friendly... I've tried to clean it up a bit... but it's still a mess...
Anyway, if now works correctly, I hope to don't mind anymore!
i still have an problem with RSS feeds in XS banner.
ÄÖÜß are not displayed correctly... i played alot with ENCODING and ENCODING_ALT and tried many RSS feeds, but no luck.
and what i dont understand is, an my localserver all works fine, but not on my server...
any ideas what can causes this problem?
Play Games at GamesCampus!
if it is apache in conifg file there are charset table
 try to disable or change default charset on yoour local server and look for result
*VOLVO CLUB*
