Post Multiple Ranks Mod Problems In Viewtopic_body.tpl
Hello,
I inserted myself the multiple Ranks Mod. The installation folded also so far completely well, but I have there however a thing, which I cannot solve.
I do not see the 2 assigned rank over my Avatar, where I assigned myself in the profile. I cannot find an error in the Mod installation. In the data base stands all SQL`s. The Mod runs also everything perfectly.
In the profile assigned all ranks correctly represented, only evenly in the Viewtopic_body.tpl not. I already tried to delete existing ranks all to make again new. In addition, did not help. I also made data base maintenance, in addition, there no improvement. I exclude an installation error to 100%.
I have times my changed files linked to the Download
***.schranzfreakka.de/multiple_ranks_2_0_3_Schranfreak_edit.rar
I hope, everybody can help me with my Problem and can take a look on my files.
MFG Schranzfreak from Germany (Sorry for my bad English)
SchranzfreakSend private message
Post Re: Multiple Ranks Mod Problems In Viewtopic_body.tpl
Topic moved to the appropriate forum...
Do you have a link to your site?
Can you see correctly the extra ranks in memberlist and profile?
Yes, i can see all correctly in Memberlist and Profile. Show on my Account...
Board
Profile
Memberlist
I still gave myself times rank partner, so that you can see, that it goes
But in the Viewtopic above my AvatarPicture i can see only the First Rank (Administrator)
MFG Schranzfreak
PS: You can download my Files (show 2 Postings above this Post).
PS2: If i want delete my PN`s, I get the Security Alert. Would have to set still on “MEDIUM” or “LOW”.
Can you help me pls ??
I want to use the multiple Ranks gladly, because it brings me nothing, if I have the Mod installed, but goes not into the Viewtopic.
I look here each day and hope for an assistance, in order to solve my problem. Thanks!!!
MFG Schranzfreak
I've tried to have a quick look to your site, but I can't find a free forum to enter... the ones I tried requires login.
Could you provide a test account?
You should also be patient a little bit... I'm doing what I can with support.
I have found the Error. I have the following forgotten with the installation:
viewtopic.php
# #----[FIND]----------------------------------------------- # $sql = “SELECT u.username, # #
----[IN LINE FIND]--------------------------------------- # , u.user_rank # #----
[IN LINE AFTER, ADD]--------------------------------- # , u.user_rank2, u.user_rank3, u.user_rank4, u.user_rank5
That was the Error in the installation.
Problem iss finished. THX !!!
Great!
