Procedure For Passage From 1055 To 1099???
Subject: Procedure For Passage From 1055 To 1099???
procedure for passage from 1055 to 1099??? I must over writing the old one?
Subject: Re: Procedure For Passage From 1055 To 1099???
written on old 1055, it works very well without problems.......thanks. :mryellow:
And run updato_to_ip.php ;)
Zuker wrote: [View Post]
Thanks you !!!
Therefore overwriting IcyPhoenix 1.0.6.6 with 1.0.9.9 and run update_to_ip.php? :?
[Sorry for my bad English ^^]
It doesn't matter the order NOW...
But now, i recommend to update all the package (excep config.php) and then run update_to_ip.php because the update chmod files ;)
Fexys wrote: [View Post]
I have executed the operation that you have said (www.myhome.com/update_to_ip.php)
the shielded upgrade does not appear, but new installation !
please help me
:cry: :cry: :cry: :cry: :cry:
tiziano wrote: [View Post]
please help me
The update_to_ip.php must to be placed in the root and not in the install folder, and it's better to run it before the upload of files, as is writed on readme instruction file in docs folder. Please use the search funtion next time... the installation procedure is explained on about 50 topics! :?
Yes andrea, but i said to run it later because it takes no problem here in this case ;)
And the files are chmodded ;)
(www.myhome.com/update_to_ip.php) running this is only of chmodding the files or it also does anything else? If its only for chmod then can u do that manually or running this file is required?
i tried to run this file from browse but it says "only for admins" and i am the admin :(
later i tried on "database update generater" but it says "The requested URL was not found on this server."
where else can i run this pliz
thx n regards
log in as admin and run the script www.myhome.com/update_to_ip.php
Thx dude....
Done as u suggested...
Got this report...
INSERT INTO phpbb_config_mg (config_name, config_value) VALUES ('url_rw_guests', '0')
+++ Successfull
INSERT INTO phpbb_config_mg (config_name, config_value) VALUES ('lofi_bots', '1')
+++ Successfull
INSERT INTO phpbb_config_mg (config_name, config_value) VALUES ('ajax_checks_register', '0')
+++ Successfull
INSERT INTO phpbb_config_mg (config_name, config_value) VALUES ('inactive_users_memberlists', '1')
+++ Successfull
INSERT INTO phpbb_config VALUES ('smilie_window_rows', '10')
+++ Successfull
INSERT INTO `phpbb_album_config` VALUES ('invert_nav_arrows', '0');
+++ Successfull
INSERT INTO `phpbb_album_config` VALUES ('show_otf_link', '1');
+++ Successfull
INSERT INTO `phpbb_album_config` VALUES ('show_all_pics_link', '1');
+++ Successfull
INSERT INTO `phpbb_album_config` VALUES ('show_personal_galleries_link', '1');
+++ Successfull
INSERT INTO phpbb_config VALUES ('bots_color', '#888888')
+++ Successfull
INSERT INTO phpbb_config_mg (config_name, config_value) VALUES ('auth_view_pic_upload', '1')
+++ Successfull
INSERT INTO phpbb_config_mg (config_name, config_value) VALUES ('enable_postimage_org', '0')
+++ Successfull
INSERT INTO phpbb_config_mg (config_name, config_value) VALUES ('enable_new_messages_number', '1')
+++ Successfull
INSERT INTO phpbb_config_mg (config_name, config_value) VALUES ('disable_thanks_topics', '0')
+++ Successfull
INSERT INTO phpbb_config (config_name, config_value) VALUES ('show_calendar_box_index', '0')
+++ Error: Duplicate entry 'show_calendar_box_index' for key 1
INSERT INTO `phpbb_config_mg` VALUES ('ip_version', '1.0.9.9')
+++ Error: Duplicate entry 'ip_version' for key 1
UPDATE phpbb_config_mg SET config_value = '1.0.9.9' WHERE config_name = 'ip_version'
+++ Successfull
UPDATE phpbb_config SET `config_value` = '.0.22' WHERE `config_name` = 'version'
+++ Successfull
UPDATE phpbb_album_config SET config_value = '1.4.1' WHERE config_name = 'fap_version'
+++ Successfull
UPDATE phpbb_config SET `config_value` = '3.0.7' WHERE `config_name` = 'upi2db_version'
+++ Successfull
CHMOD Files
CHMOD 0777: cache
+++ Error CHMOD 0777: cache
CHMOD 0777: ctracker/logfiles/logfile_attempt_counter.txt
+++ Error CHMOD 0777: ctracker/logfiles/logfile_attempt_counter.txt
CHMOD 0777: ctracker/logfiles/logfile_blocklist.txt
+++ Error CHMOD 0777: ctracker/logfiles/logfile_blocklist.txt
CHMOD 0777: ctracker/logfiles/logfile_debug_mode.txt
+++ Error CHMOD 0777: ctracker/logfiles/logfile_debug_mode.txt
CHMOD 0777: ctracker/logfiles/logfile_malformed_logins.txt
+++ Error CHMOD 0777: ctracker/logfiles/logfile_malformed_logins.txt
CHMOD 0777: ctracker/logfiles/logfile_spammer.txt
+++ Error CHMOD 0777: ctracker/logfiles/logfile_spammer.txt
CHMOD 0777: ctracker/logfiles/logfile_worms.txt
+++ Error CHMOD 0777: ctracker/logfiles/logfile_worms.txt
CHMOD 0777: files
+++ Error CHMOD 0777: files
CHMOD 0777: files/album
+++ Error CHMOD 0777: files/album
CHMOD 0777: files/album/cache
+++ Error CHMOD 0777: files/album/cache
CHMOD 0777: files/album/med_cache
+++ Error CHMOD 0777: files/album/med_cache
CHMOD 0777: files/album/wm_cache
+++ Error CHMOD 0777: files/album/wm_cache
CHMOD 0777: files/posted_images
+++ Error CHMOD 0777: files/posted_images
CHMOD 0777: files/thumbs
+++ Error CHMOD 0777: files/thumbs
CHMOD 0777: images/avatars
+++ Error CHMOD 0777: images/avatars
CHMOD 0777: logs
+++ Error CHMOD 0777: logs
CHMOD 0777: pafiledb/uploads
+++ Error CHMOD 0777: pafiledb/uploads
CHMOD 0777: pafiledb/cache
+++ Error CHMOD 0777: pafiledb/cache
CHMOD 0777: pafiledb/cache/templates
+++ Error CHMOD 0777: pafiledb/cache/templates
CHMOD 0777: pafiledb/cache/templates/ca_aphrodite
+++ Error CHMOD 0777: pafiledb/cache/templates/ca_aphrodite
CHMOD 0777: pafiledb/cache/templates/mg_themes
+++ Error CHMOD 0777: pafiledb/cache/templates/mg_themes
CHMOD 0666: includes/def_themes.php
+++ Error CHMOD 0666: includes/def_themes.php
CHMOD 0666: includes/def_tree.php
+++ Error CHMOD 0666: includes/def_tree.php
CHMOD 0666: includes/def_words.php
+++ Error CHMOD 0666: includes/def_words.php
It has not done chmod so am doing it manually...
Thx a lot
Regards
what type of server are you running? maybe that's why the chmod didn't aply
anyway, you got your site working fine, right?
no without the right CHMOD permission shouldn't work well :mricy:
but he says he made the chmod manually mate...
Generation Time: 0.1477s (PHP: 14% SQL: 86%)
