dllrsoft
 Don't Work You Tube, Emff And Google Video Buttons
Hello, at first, I'm sorry for my bad english...
I try to update XS to IP, but I have one problem... When I go to post one thread the buttons of You Tube, Google Video and EMFF don't work...
This only happens when I update from my data base of my Web, that is to say, that I have proven to update a data base XS cleans (just installed XS to update to IP) and yes they work...
PD: Tags yes works, if I put tag of You Tube, yes works the video, but the button does not work...
¿How I solve this problem?
Greetings and thanks beforehand!!
#1 Tue 20 Mar, 2007 01:40 |
sonoangelo
 Re: Don't Work You Tube, Emff And Google Video Buttons
syncronize all the tables from ACP > Database > Maintenance >
I had the same problem and i solved doing this
#2 Tue 20 Mar, 2007 07:36 |
dllrsoft
Thanks to respond, but the problem has solved... magicaly... jeje
Greetings!!
#3 Tue 20 Mar, 2007 13:14 |
dllrsoft
Sorry for double post... But the problem persists...
I do what sonoangelo says, but works either…
Greetings!!
#4 Tue 20 Mar, 2007 14:50 |
Zuker
any url to see the problem...?
and a test user please
#5 Tue 20 Mar, 2007 16:37 |
dllrsoft
Ok, Zuker, I'm sorry...
URL: www.dllrsoft.es
User: test
Password: test
After this, I think that the problem is caused for the buttons of the spanish languaje... but I'm not sure... I'm to prove this and I comment you...
Greetings!!
#6 Tue 20 Mar, 2007 20:47 |
dllrsoft
The problem is solved... The solution is upload Icy Phoenix with the images in english and, after, upload the images of your languaje...
Thanks for your time and have a nice day!!
Greetings!!
#7 Tue 20 Mar, 2007 21:11 |
algs163
Thanks dllr, it happened to me the same , but I could fix it ..
thanks you very much.
goodbye.
#8 Tue 20 Mar, 2007 23:07 |
Zuker
great you solve it dllrsoft
greets
#9 Wed 21 Mar, 2007 01:12 |
