FAP SUPPORT - Invalid Combination Of Category Id And Authentication Data
Subject: FAP SUPPORT - Invalid Combination Of Category Id And Authentication Data
When you look (as a normal user, so not an admin) to a personal album that has not yet been created you will see an error with:
Invalid combination of category id and authentication data
I have fixed it this way:
OPEN
  1. /album_mod/album_personal.php
  1. if ( album_check_permission($auth_data, ALBUM_AUTH_UPLOAD) == true )
  2. {
  3. $template->assign_block_vars('index_pics_block.no_pics.manage_personal_gal_folders', array());
  2. {
  4. }
  5. else
  6. {
  7. message_die(GENERAL_MESSAGE, sprintf($lang['Personal_gallery_not_created'], $username));
I don't know if it's good, but it works. :P
Subject: Re: Invalid Combination Of Category Id And Authentication Da
I do not experience this problem and I'm not sure of your solution,
but Hey...if it works :wink:
Artie wrote: [View Post]
http://www.google.nl/search?hl=nl&c...nG=Zoeken&meta= :P
This should have been solved in 1.4.2... I think you cannot replicate it here... right? :wink:
Generation Time: 1.878s (PHP: 1% SQL: 99%)
