Post FAP CUSTOMIZATION - Wanting To Add A Personal Gallery Management Link
Im using a profile information organizer hack, user cp organize to be specific. Well Im trying to add links in the profile control panel to manage your personal categories. I got the upload and my pictures figured out.  Here is what i added
'U_YOUR_PERSONAL_GALLERY' => append_sid("album.$phpEx?user_id=". $userdata['user_id']),
'UPLOAD_PERSONAL_GALLERY' => append_sid("album_upload.php?cat_id=1&user_id=". $userdata['user_id']),
'U_USERS_PERSONAL_GALLERIES' => append_sid("album_personal_index.$phpEx"),
'U_PERSONAL_CAT_ADMIN' => append_sid("album_personal_cat_admin.$phpEx?cat_id=$cat_id"),
the problem im having is with this line
It cant find the $cat_id. what would i need to add to this non album page to pull the users personal $cat_id
thanks
Adam
luckyou03Send private message
Post Re: Wanting To Add A Personal Gallery Management Link
I think  adding something like this may work
$album_user_id = $userdata['user_id'];
$sql = "SELECT c.cat_id
                FROM ". ALBUM_CAT_TABLE ." AS c
                WHERE c.cat_user_id = '$album_user_id' AND c.cat_parent = 0
                LIMIT 1";
        if( !($result = $db->sql_query($sql)) )
            message_die(GENERAL_ERROR, 'Could not query category information', '', __LINE__, __FILE__, $sql);
        if ($db->sql_numrows($result) == 0)
            $create_personal_cat_manage_link = append_sid('album_personal_cat_admin.' . $phpEx . '?action=create&user_id=' . $album_user_id);
        else
                $thisrow = $db->sql_numrows($result) ;
                        $cat_id = $thisrow['cat_id'];
            $create_personal_cat_manage_link = append_sid('album_personal_cat_admin.' . $phpEx . '?cat_id='.$cat_id.'&user_id=' . $album_user_id);
        $db->sql_freeresult($result);
'U_PERSONAL_CAT_ADMIN' => $create_personal_cat_manage_link,
You'll also need $cat_id for your UPLOAD_PERSONAL_GALLERY
ArtieSend private message
First off, thank you. I tried the code and im getting errors maybe if you looked at the whole thing it might be better, its not to big.
<?php
 *                               cpl_menu.php
 *     mod version          : 1.0.5
 *   date                 : Monday, 08.22.2005
 *   copyright            : Dustin < adminkrez@dumbassjones.com >
 *   This program is free software; you can redistribute it and/or modify
 *   it under the terms of the GNU General Public License as published by
 *   the Free Software Foundation; either version 2 of the License, or
 *   (at your option) any later version.
if ( !defined('IN_PHPBB') )
    die("Hacking attempt");
                LIMIT 1";
            $create_personal_cat_manage_link = append_sid(album_append_uid('album_personal_cat_admin.' . $phpEx . '?action=create&amp;user_id=' . $album_user_id));
        else
            $create_personal_cat_manage_link = append_sid(album_append_uid('album_personal_cat_admin.' . $phpEx . '?cat_id='.$cat_id.'user_id=' . $album_user_id));
$template->set_filenames(array(
    'cpl_menu_output' => 'profile_cpl_menu.tpl')
$template->assign_vars(array(
    'L_CPL_REG_INFO' => $lang['Registration_info'],
    'L_CPL_PROFILE_INFO' => $lang['Profile_info'],
    'L_CPL_AVATAR_PANEL' => $lang['Avatar_panel'],
    'L_CPL_PREFERENCES' => $lang['Preferences'],
    'L_CPL_SETTINGS_OPTIONS' => $lang['Cpl_Settings_Options'],
    'L_CPL_BOARD_SETTINGS' => $lang['Cpl_Board_Settings'],
    'L_CPL_PRIVATE_MESSAGES' => $lang['Private_Messages'],
    'L_CPL_NEWMSG' => $lang['Cpl_NewMSG'],
    'L_CPL_PERSONAL_PROFILE' => $lang['Cpl_Personal_Profile'],
    'L_CPL_VIEW_PROFILE' => $lang['Cpl_View_Profile'],
    'U_CPL_NEWMSG' => append_sid('privmsg.'.$phpEx.'?mode=post'),
    'U_CPL_REGISTRATION_INFO' => append_sid('profile.'.$phpEx.'?mode=editprofile&cpl_mode=reg_info'),
    'U_CPL_PROFILE_INFO' => append_sid('profile.'.$phpEx.'?mode=editprofile&cpl_mode=profile_info'),
    'U_CPL_PREFERENCES' => append_sid('profile.'.$phpEx.'?mode=editprofile&cpl_mode=preferences'),
    'U_CPL_BOARD_SETTINGS' => append_sid('profile.'.$phpEx.'?mode=editprofile&cpl_mode=board_settings'),
    'U_CPL_AVATAR_PANEL' => append_sid('profile.'.$phpEx.'?mode=editprofile&cpl_mode=avatar'),
$template->assign_var_from_handle('CPL_MENU_OUTPUT', 'cpl_menu_output');
The first error i got was
Parse error: syntax error, unexpected '}' in /home/sweetpro/public_html/cpl_menu.php on line 48
so i removed the } and got this error
Fatal error: Call to undefined function: album_append_uid() in /home/sweetpro/public_html/cpl_menu.php on line 46
I have edited the code that I supplied above..... try it now.
The code didn't cause any errors but its not pulling the cat id tho. any ideas?
viewprofile
Oooops !
change
to
$thisrow = $db->sql_fetchrow($result);
One more little thing for people wanting to use this in the future
Find
$create_personal_cat_manage_link = append_sid('album_personal_cat_admin.' . $phpEx . '?cat_id='.$cat_id.'user_id=' . $album_user_id);
and change to
After that it works excellent,
Thank you
Glad you got it working.
Good eye on the &
is cat_id of user's personal gallery always the same as user's id?
because i tried putting your code in page_header since i want the management link in the overall header but it screws up
so instead of your code, i simply put in page_header.php
'U_PERSONAL_CAT_ADMIN' => append_sid('album_personal_cat_admin.' . $phpEx . '?cat_id='.$userdata['user_id'].'&amp;user_id=' . $userdata['user_id']),
now it seems to be working.....well, unless cat_id of user will change....then i have a problem
meaniemeSend private message
They are not the same, it just happened to work out that way for you.
It may work without specifying the cat_id, altogether. Try it by just adding the user_id part to the url
i removed cat_id, so far seems to work...so with this should just be one liner and thus won't need the sql call for cat_id
love simplicity thanks!
You are welcome
Hello, I find this helpful... but what are the {links_name} ? I cant figure that part out...
Pete_ZSend private message
