Problem With The File .htaccess
Subject: Problem With The File .htaccess
Hello!!!
My problem is that when I'm uploading the file .htaccess my host says that filetype is not allowed, but I tried to upload with another name ( htaccess ) and finally it's uploaded... i wonder if that would generate problems when I install the forum...
sorry for my bad english :mrblue: xD
Subject: Re: Problem With The File .htaccess
your forum should work anyway... but the .htaccess are at the package for security reasons ;)
Thank you Zuker, so this file is very important... do you think it's gonna work with another name? htaccess without the point (.) I mean
no beacuse htaccess is the extension of the file ;)
if you want to learn more about htaccess
http://httpd.apache.org/docs/1.3/howto/htaccess.html#when
google is your friend
Try renaming it to htaccess.txt
Upload and then (on the server) rename it back to .htaccess
Artie wrote: [View Post]
If the server doesn't support .htaccess he cannot do anything :(
Sorry, in the future I should pay more attention to what is written, huh? :mricy:
Generation Time: 0.0855s (PHP: 20% SQL: 80%)
