Hi, some buttons in my moderator-control panel had no text.
I inserted the following into my german language file lang_album_main.php .
// ModCP
$lang['Move'] = 'Bewege nach Kategorie';
$lang['Lock'] = 'Sperren';
$lang['Unlock'] = 'Entsperren';
Now it`s okay.
FAP SUPPORT - Moderator Control Panel Buttons
Subject: Re: Moderator Control Panel Buttons
Thanks for the hint...
Witch FAP Version you are using?
Oh, right.
I can see this lines in lang_main.php
But it doesn`t work.
Crazy!
@TheSteffen: I have 1.41 .
I have also a language-problem with my newpost - function.
Probably I made a failure while installing the mod.
But else everythings works fine.
I work with CH2.16c .
Does anybody know what can be my failure?
Artie wrote: [View Post]
Oh, right.
Crazy!
Strange, like Artie sad, this should be in lang_main.php
I don't know why it's not working for you.
Could you please attache you lang_main.php ... maybe there is a mistake in it.
Generation Time: 0.363s (PHP: 5% SQL: 95%)
