Can I Copy Part Of Forum Structure ?
Subject: Can I Copy Part Of Forum Structure ?
I need copy part of another forum phpbb to my forum icy last version.
Just I need copy one forum ( from 4 existent ) with all subforums but without message and permisions.
Just part of structure.
I have full admin acces to this forums.
Thanks!
Subject: Re: Can I Copy Part Of Forum Structure ?
ciufuliciboy wrote: [View Post]
Thanks!
If you are not so good with PHP I would suggest to import all the DB and then manually delete what you don't need.
It should be easiest.
Otherwise you may try playing with phpMyAdmin and export/import only the table for forums and categories.
I make this with users table and it is working.
I will test your sugestion!
Thanks !
Generation Time: 0.0947s (PHP: 17% SQL: 83%)
