Post Error Synchronize User Post Counters/new Post
hello, I have a problem with the accountant of messages, if there are new messages or to mark like sights, these options do not work or since they are not updated when the users are responding or creating messages. I have proven to synchronize forums and messages, and the tools of the data base and are solved but when it becomes to postear they return to be bad. As it can be the problem?
Url: http://www.clandios.net
version: Icy Phoenix 1.0.11.11 RC
no new mods installed.
12siglosSend private message
Post Re: Error Synchronize User Post Counters/new Post
hello, nobody knows the cause of the problem?
I didn't understand your problem :S
User1 = 5 post in the accountant/post real 8, accountant does not work New read messages them frame like, but really does not mark them. I have used the tools of the data base without solution.
Are you using DB or Cookies for storing Unread Messages?
If you are using cookies the problem could be related to a wrong configuration of your browser. If you are using UPI2DB then some strange behaviours occurs when posts you have to read are being deleted/moved.
