Post I Cannot Change Configuration Of The Forum In ACP
HEllo
I enter the ACP, I enter Configuration/forum...
attempt to change to the size of avatars and more... and...
At the time of wanting to keep, it is to say at the time of giving clik in sending appears the following text:
CBACK CrackerTracker cannot correctly work the operation of the data base.
... And already, there are no changes... although to send to him without creating no modification, it leaves the text to me. I hope can help me, THANKS!
marioslnSend private messageVisit poster's website
Post Re: I Cannot Change Configuration Of The Forum In ACP
I've same problem...
felix968Send private message
mariosln wrote: [View Post]
HEllo
Hi
I can change what i will and it works ... also at my test site
what IP do you use ???
Pepi
pepiSend private messageVisit poster's website
FINISHEE
me go to  ACP
and  cracker trake
disable all options.. and  LIST!!!!
It should work fine in the final release.
I have icy phoenix 1.01.11.11 and I still have that problem.
aliks0905Send private message
aliks0905 wrote: [View Post]
Disable all options in ACP of ctracker. it will never bother you again!
cyberSend private message
Try the new release and let me know.
