Hello once again,
I know Im asking too many questions - considering this is my third post within the last hour, but I only discovered this great community yesterday night :) - but please be assured I will not hassle anymore after this one, for a while :?
Ok heres the quiestion: How do i remove the Recent Pictures Block from the Categories & Sub-Categories ?
I have managed to remove it form the Album Index page from the CLowN settings in the ACP - is there a switch for removing the block from categories & sub-cats in the ACP too ?
If not, what do i need to do to remove it ?
I'm on phpbb 2.22 & FAP 1.2.1 (my forum : http://accessability.co.in/community/)
Thanks again,
Vic
FAP CUSTOMIZATION - [Sorted] Removing Recent Public Pics Block From Categories
Subject: FAP CUSTOMIZATION - [Sorted] Removing Recent Public Pics Block From Categories
Subject: Re: Removing Recent Public Pics Block From Categories &
You are using an old version of FAP.....
I don't remember much about that version, but in the current version there is a ACP switch for this....
or you can just remove it from the template file.
OPEN templates/YOUR TEMPLATE/album_cat_body.tpl
FIND AND REMOVE
FIND AND REMOVE
Artie - you really are a star
problem sorted in a flash !!
Vic
Vic
Generation Time: 0.256s (PHP: 7% SQL: 93%)
