Post FAP SUPPORT - Private Album Pics With Red X Under Viewprofile?
When viewing profile of a user, there is a strip at the bottom to show recent pics from the member...
but when that member turns the category that the picture is stored in to private, the picture becomes a red X (broken image) but the description and other details still exist
is this as designed? seems it should not even show the picture...is there something wrong with permission settings?
Filesize: 9.87 KB
Viewed: 6432 Time(s)
meaniemeSend private message
Post Re: Private Album Pics With Red X Under Viewprofile?
I think it is a bug. I have noticed it myself, in the past, but had forgot.
Maybe MG is listening and  will fix for the next release
ArtieSend private message
hmm i'm thinking it's some easy check permission function to insert
it seems this is bad because, then user's picture detail is not private even though picture is not showing, which with some details can make people even more curious what the picture is....esp if the details are "dirty"
i hope there is a fix
In theory it should be enough adding something like this (taken from thumbnail) in the cycle:
$album_user_access = album_permissions($album_user_id, $cat_id, ALBUM_AUTH_VIEW, $thispic);
if ( $album_user_access['view'] == false )
    message_die(GENERAL_MESSAGE, $lang['Not_Authorised']);
But I need to have a further check when I'm not so tired... please wait...
i have no idea if this is valid, but here's what i did:
after
    $template->assign_block_vars('recent_pics_block.recent_pics', array());
        for ($j = $i; $j < ($i + $cols_per_page); $j++)
            if( $j >= $totalpicrow )
                break;
i added
// Check the permissions
$album_user_access = album_permissions($recentrow[$j]['cat_user_id'], $recentrow[$j]['pic_cat_id'], ALBUM_AUTH_VIEW, $recentrow[$j]);
//    message_die(GENERAL_MESSAGE, $lang['Not_Authorised']);
else
            $template->assign_block_vars('recent_pics_block.recent_pics.recent_col', array(
etc etc etc....
Is it working fine?
