Hello mates!!!
I have a big problem I was going to crete a new forum phpBB one in a subfolder but I had an error And I replaced the IP ones with them....
Now my web is giving me lots of problems and I dont know how to solve it to conserve the things I had and dont lose any information
PS: i dont have recently backup :(
need help plz
Big Problem
Subject: Re: Big Problem
Can you give us a link to test?
Can you give us some extra infos about your old installation and mods?
My web is http://www.guerrerosdelkaos.es/foros/ the last estable version
I don't have any mods installed.
Thank you
Problem solved
Thank you
Problem solved
all is correct....
I have another error too, when I go to my IP forum, by IE 7 or less it says the page has an error...
How can I know which error is?
your javascript is not nested correctly...
- <script language="javascript" type="text/javascript" >
- iw_ad_cliente='16449cdd169d248c891506ac8628480d';
- iw_ad_pagina=21512;
- iw_ad_cod=13489;
- iw_ad_tm=2">2">2">2;
- iw_ad_ancho=468;
- iw_ad_alto=60;
- iw_ad_formato='ad_468x60';
- iw_ad_cad='6fffe05d6330ddbe00d46c19e989dff3';
- iw_ad_tipo=2">2">2">2;
- iw_ad_tipocod=2">2">2">2;
- iw_ad_modo=1;
- </script>
- <script language="javascript" src="http://www.impresionesweb.com/r/banner_iw.php?idrotador=21512&tamano=468x60"></script>
- </p>
- <script type="text/javascript">
Generation Time: 0.0854s (PHP: 21% SQL: 79%)
