Post Phpca Integration For Icy Phoenix
Was wonder if anyone has this running in their forums and if it works without too much customization of the code outside the installation of it. I was interested in trying this out once ICY goes final.
And for those that do not know phpca is a integrated classified ad system that uses the forums.
Check it out here http://www.phpca.net/
-D1-
Check out my new website:
Adult Forums - A place where everyone can fit in.
Currently running v1.1.10.25 RC3
darkoneSend private message
Post Re: Has Anyone Have Phpca Integrated Into ICY?
Sounds brilliant, darkone.  Let us know if it works.  I for one would be interested in integrating it with IP.
tc1967ukSend private message
Thanks TC
I will try to get this installed after I have got the final release installed of ICY because I want to play with it. And I will let you know how it goes. Anyone else play with phpca and have it running with ICY so I can see it?
-D1-
I will give a try when gold release is out
I've been using phpCA for about two years.. It is a wonderful little script.. I just found ICY today, but plan on integrating it into my new forums.
IP Version: 1.1.0.15a
Server Type: Linux
Apache Version: 1.3.37
PHP Version: 5.0.5
MySQL Version: 4.1.22-standard-log
Globals: Off
Safemode: Off
drexfulSend private message
Hi
You can try my Phpca for ICY (sorry english button are from subSilver)
Pepi
phpCA-0.5.6.rar
Description: Phpca for ICY
Filename: phpCA-0.5.6.rar
Filesize: 589.86 KB
Downloaded: 460 Time(s)
pepiSend private messageVisit poster's website
There is an error in the SQL import..
Could not query ads config information
DEBUG MODE
SQL Error : 1146 Table 'vballm_icy1.ip_ads_config' doesn't exist
SELECT * FROM ip_ads_config
Line : 47
File : ads_common.php
The SQL table prefix needs to be changed from phpbb_ to ip_ if you are using a vanilla install.
Server Type: Linux
PHP Version: 5.0.5
Globals: Off
Safemode: Off
Hi
i think in the DB must all sql phpbb_ i see youhave other ....
on first install i set it on phpbb_
Pepi
Got it almost working..
Will post results soon
Server Type: Linux
PHP Version: 5.0.5
Globals: Off
Safemode: Off
Ok.. After working out the bugs and conversions, I now have the mod working for ICY.
One thing to note is the TPL files are phpCA default. I did not modify them to ICY.. They work with ICY as-is, but you can change them to your liking.
Thanks to Pepi for pointing me in the right direction..
Here you go
IP_phpCA_Mod-0.5.6.rar
Description: Updated
Filename: IP_phpCA_Mod-0.5.6.rar
Filesize: 292.5 KB
Downloaded: 262 Time(s)
Server Type: Linux
PHP Version: 5.0.5
Globals: Off
Safemode: Off
drexful, this sound like something I'm looking for.
Do you have a link to this mod working with Icy.
ArtieSend private message
Hi Artie,
You can get a good idea of what the mod looks like at the developer's website.. Visit http://www.phpca.net/phpBB2/adverts.php for the demo
Enjoy
P.S. I should also let everyone know that if you have problems with my version of the script, feel free to reply to this topic and I will respond. The only problems I've run into are CTracker errors.. Those are easy to fix and I think I got most of them.
- Drex
Server Type: Linux
PHP Version: 5.0.5
Globals: Off
Safemode: Off
Thanks, I will check it out.
Artie wrote: [View Post]
Hello Artie
Here on my site run it on ICY
http://www.cool-lighter.at/myhome/adverts.php
Pepi
Thanks pepi.
I think I will like this.....
