Post Seeing Error When Displaying New Profile Fields
Hey Everyone
I was noticing when trying to track down my CrackerTracker issues that when looking over the profile fields, that when you create some new fields and you set 'Set as Required' to No/False. That when you try to register or you view your profile it shows an '*' next too the new field which tells you its manditory. Which this is not the case because you set it too not manditory.
How do we fix this?
-D1-
Check out my new website:
Adult Forums - A place where everyone can fit in.
Currently running v1.1.10.25 RC3
darkoneSend private message
Post Re: Seeing Error When Displaying New Profile Fields
Anyone else see this issue?
I don't have this problem...
I've tried on a test site and no asterisk upon registration is field is not mandatory.
Can you try to post here how did you create the new field?
Which type of field?
