Re: Default User Group
Since this could be useful for other users... I've moved it to Docs section.
Thanks Tom!
P.S.: just a little note... you have to update the groups after having enabled this option (this means flagging these two fields Add/Update new users and Delete/Update old users)!
Thanks Tom!
Do you have to do this just once or periodically for members to be added?
The time now is Mon 25 Aug, 2025 02:00 • All times are UTC + 1 Hour [DST enabled]
